Don Plumley's Avatar
Interim Project Update: Aluminum Floorboards
In the floor of a 993 is a reinforcing channel, and on the pax side there is the positive battery cable and a thick harness cable. Normally, there is a very heavy foam pad that protects the stuff and levels the area for the carpeting.
Since I've removed all of that, I need to make the floor flat. If you look at the cup car pictures, there is some sort of factory piece that makes the area under the pedals level. So I set out to replicate this.
Here are photos of the floor after removal of the heavy stuff:
I made a template from cardboard:
Got some scrap 0.080 aluminum:
Used rubber stoppers and a fabricated angle bracket to support the panel:
(the blue tape is holding a rubber piece while the glue dries)
Results:
The floorboard is mounted with two fasteners - one is the existing stud that holds the carpet in place (in the rear), further forward, one of the SS screws you see screws into a clip fastener I mounted. I roughed up the surface to make it more dull (less reflection) and less slippy. There is some no-slip stuff under the accelerator pedal. Once I attach the seat and see where my feet hit the floor when I climb in, I'll put a few more strips in place.
Rennline has a set of similar track mats available, but they seemed to need to have the padding underneath. Anyway, for $20 in scrap aluminum and $10 in fasteners, this was a fun project. Oh, they weigh about 2# each, the padding was at least 5 if not 10# a side.
Off to the fabricator to get a half-cage spec'd....
Don Plumley
M235i
Old 02-08-2006, 09:24 AM
PRO Motorsports
Tyson Schmidt's Avatar
Hey, while you got your tools out, why don't you make a second set?
I know a guy with a C2 that needs some of those!
Looks awesome Don!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 02-08-2006, 09:33 AM
I saved the templates!
It's pretty much a bespoke process depending on what is under there. But I'm sure we can work something out!
Thanks!
Don Plumley
M235i
Old 02-08-2006, 09:37 AM
I saw a similiar thing on ww2 hurricanes just behind the pilots head.
Are you expecting ground fire when overtaking?
Old 02-08-2006, 10:17 AM
Cory M's Avatar
Looks good Don, but I think you need to drill a few more holes in the bracket it looks way too heavy
I'm curious why you're only going with a half cage. If you've stripped your car this far why not do the full cage all at once?
Old 02-08-2006, 10:24 AM
Bill Verburg's Avatar
Looks good Don!
Bill Verburg
Old 02-08-2006, 01:37 PM
