I need a picture of a 930 starter
I am now wiring up my conversion 3.3 T into the Carrera. I was only using 2 wires for the starter before and nom the harness for the 930 has 3 wires going to it.
1. Main hot lead 2. Yellow with a stripe 3. Solid yellow I am guessing the 3rd is for the cold start injector hot lead? Does anyone have a picture of a 930 starter? |
Well, you don't say what year engine or harness you are using, so this reply may be akin to peeing in the wind. So, picking a year at random, you probably have a big fat black wire from the battery and an a smaller red one from the alternator attached to terminal 30 on the starter. There should be a yellow one attached to terminal 50. The (blue?) striped yellow one should attach to 15a at the starter and go to connector at the cold start valve. Sorry, I have no picture.
Hope this helps, JR
We need not be gracious when our enemy dies. Civility is only afforded those who don't go to their grave trying to destroy us and ours. E. M. Burlingame |
930 motor and harness, 915 transmission and starter. Is the picture I posted correct?
78 motor and harness, sorry, left that out
Maybe this diagram will go along with the above comments to help ...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Maybe I need to get a mirror and crawl back under the car, I am thinking the starter said 50 & 16, not 15a. And again after being under this car all day everything is a blur.
I hope this thread helps...and the ones embedded within...
Starter solenoid yellow wire connection - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
