RSR style Fuchs
I just finished refinishing my Fuchs. I bead blasted my wheels and then clear coated them. Then I masked them and shot them with black single stage paint. The clearcoat made the bead blasted Alu a little darker than anodizing would have. So if I do this again I will paint the wheels silver first instead of clear.
I can't seem to upload pics now. Later Dean |
a work of art!!
Thanks. I just asked the wife what she thinks of my wheels. She said "you mean those wheels in my living room? Very professonal."
Dean |
They look great, Dean. I am anxious to see this look on the car.
I see what you mean by the clear being shiny. I kind of prefer the "matte" look, but those wheels will be beautiful. Nice job. JA |
dean,
Any pics of a bead blasted wheel before clear coat? |
i have a set of lindseys on order in the rsr finish. they basically weld the center to the bbs barrel and bead blast the whole thing and for powdercoating they use a frosted clear. they have in the past polished the outside rim but this takes the powdercoat off and leaves raw aluminum. i've bead blasted aluminum castings also and i get the darker/slightly blueish color after putting a clear coat on the parts also. the wheels look great, the gloss clear is likely easier to clean.
Thanks for the comments.
I would have prefered a more matte finish also and not so shiny but I had the clear hangin around for years and wanted to use it on something. Plus it was an experiment in low maintanence RSR wheels. I don't even know if the clear will hold up on Alu. Dupont didn't recommend clearing Alu. Here is a pic of beadblasted wheel that has a conversion coating on it. |
Very nice!
Whats a 'conversion coating? |
A conversion coating is basicly an acid type product that you treat bare Alu with before painting. Different companys have different products.
Dean |
From the picture, the conversion coating looks a lot like the original RSR finish, if you highlighted it with black. Is it the kind of thing that would stand up to any use?
Where is the drool icon? http://www.pelicanparts.com/support/smileys/men_ani.gif
Extremely nice!!! http://www.pelicanparts.com/support/smileys/clap.gifhttp://www.pelicanparts.com/support/smileys/clap.gifhttp://www.pelicanparts.com/support/smileys/clap.gifhttp://www.pelicanparts.com/support/smileys/clap.gif |
The wheels are 7"& 8" x16. I called them RSR style cause they aren't real RSR wheels Thanks Dean |
Could you post the actual products which you used?
Thanks, Doug |
RSR "Style" is a "rough matte" finish....
See my thread..."Economy RSR finish".... Wil |
Sweet!
Rated S
I used Twin Etch from Martin-Sinour (spelling) on the beadblasted wheels. Then I cleared them with Dupont 7500S. Then I masked them, and cleaned them with Dupont Prepsol, then skuffed the clear with 1000 grit paper. Then I cleaned them with Dupont Laquer and Enamel cleaner. Then I shot the black Dupont Chromeone paint. I was told by Dupont that they don't recommend clearing bare Alu. They suggested painting the wheels. I think painting the wheels might look more RSRish and might last longer than the way that I did it. But I bet my clear lasts a long time. Dean |
| All times are GMT -8. The time now is 11:25 AM. |
