front bilstein retaining pin
I was able to change the rear shocks in my 930 turbo without much trouble (easily said after I finished, right?).
I began the front change by trying to hammer out the bottom retaining pin with a roll pin punch. The pin quickly started to give and I thought I had it licked but at about 1/3 inch inch, it stopped moving. no matter how hard I hammer, it ain't budging. It looks like I'll need another approach.
I read in Wayne's book about drilling it out. Two questions
1. Is there a problem with metal shavings remaining in the strut?
2. What kind of drill bit functions best for this?
Thanks guys.
Q.
2004 996 TurboS Cab
2005Cayenne Turbo S
1988 930 Turbo Cab
2004 BMW M3
2007 Range Rover Sport
Old 02-15-2006, 04:56 PM
Member w/ Title Problems
Jason Porter's Avatar
Did you try spraying it with PB and hammering it back and forth a little. It should come right out at that point. BTW - How big is your hammer?
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 02-15-2006, 05:01 PM
20 oz. hammer. Dumb question, What is PB?
Q.
2004 996 TurboS Cab
2005Cayenne Turbo S
1988 930 Turbo Cab
2004 BMW M3
Old 02-15-2006, 05:04 PM
Only dumb question is the one not asked. PB Blast, it's a penetrating oil spray, although you could use WD-40, too. I use a 3lb Estwing and tap with necessary force It usually doesn't take much...
Old 02-15-2006, 05:09 PM
Thanks.
Q.
2004 996 TurboS Cab
2005Cayenne Turbo S
1988 930 Turbo Cab
2004 BMW M3
Old 02-15-2006, 05:10 PM
No problem.
Old 02-15-2006, 05:16 PM
mark '87 930's Avatar
i am considering changing my ball joints and since I'm there, maybe change the front shocks as well. Do your struts have an insert which you are simply changing, or do you have to do the entire strut assembly for the big bucks? i have an 87 930 and really looking to doing this.
the ball joint tool isn't cheap though.
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 02-15-2006, 06:01 PM
Inserts... You should be able to loosen the ball joint with a hammer and punch, backing it out slowly, but then again, I'd get the tool if I were you. Just make sure it's on perfectly straight, and you've got a good grip on it, or you may do more harm than good...
Old 02-15-2006, 06:33 PM
Here is my dumb question.
Is a roll pin punch flat tipped or slightly pointed?
Did mine 1 1/2 yrs ago and if remember right I ended up using a flat tipped 1/4" punch.
The other punch I used was slightly pointed and as I hammered it started going into the roll pin and expanding it.
Quincy
Fountain Valley, CA
'83 SC, '13 P-GTS
"Air cooled, fountain pen guy, living in a water cooled, iPhone world"
Old 02-15-2006, 07:09 PM
I would use a flat point, but then again, you should be able to use either. It's not going to expand that much in a press fit area like that...
Old 02-15-2006, 07:35 PM
randywebb's Avatar
pointed punch is more likely to wind up inside the roll pin - expand it so it won't move and break off...
find that fun thread where a guy had that happen recently
so ... flat
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-15-2006, 08:13 PM
ianc's Avatar
The roll pin is pointed on the end. Don't drill it; it's extremely hard and will give you no end of trouble. Optimally, find a punch just the size of the bore in the strut and use that. Follow Jason's advice and hammer it in a little, then out a little more, soaking it all the time with penetrating oil. Gripping the protruding end with vice grips might contract it a hair and make it a little easier, or you can try beating on the vice grips (with a rubber mallet of course). Good luck,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 02-15-2006, 10:38 PM
vash's Avatar
my money is on the wrong punch...
the "necked down" section on the punch needs to be long enough to go the full length. i once tried it, and didnt realize the shoulders of the punch was butting up against the shock body,,DOH! i took a new pin to the hardware store and matched up the diameters closely (with a nice flat point). it took two hits. in my experience, once you get the pin moving, the battle is won.
poof! gone
Old 02-16-2006, 08:31 AM
I had the same problem. The punch butted up against the strut. Once I went to a narrower punch, The pin came out.
Now I'm having a hard time hammering the new pin in. Boy!! talk about stubborn, even to get it started. I'm half way in and pounding hard. I hope I don't bend it.
Q.
2004 996 TurboS Cab
2005Cayenne Turbo S
1988 930 Turbo Cab
2004 BMW M3
Old 02-17-2006, 01:16 PM
Finished yet?
Old 02-17-2006, 07:15 PM
