TxCarerra
Guest
Posts: n/a
Question Fender Liner or Shield?
Greetings, all. This is my first post here because all of my previous questions were answered by the numerous excellent posts in this forum. I own a 1986 Iris Blue 911 coupe with 84,000 miles, and will post pics soon.
So here's my burning question: Does anyone make a liner or shield for the inside of the front fenders on this era 911? I've read numerous posts about the garbage that accumulates in the nooks and crannies and this seems an obvious solution. Many Thanks in advance.
-Mike
Old 02-14-2006, 09:54 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
Not that I know of.....Just remove the wheel during some of your clean-ups....
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 02-14-2006, 10:31 AM
Re: Fender Liner or Shield?
Yes, Wurth makes one......it's called Body Schutz
Welcome to the board.
Warren & Ron, may you rest in Peace.
Old 02-14-2006, 10:55 AM
Recreational User
porschenut's Avatar
You're not getting any more answers until you post pics.
Old 02-14-2006, 11:11 AM
Yes....someone makes this....I recall just such an answer either on this list or on Rennlist..
The maker is in Europe and it's the common ( for "other" cars) black plastic lining... thickness like a plastic gallon milk jug...but made for 911's, both front and rear applications.
I'll see if I can dig it up or do a search...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-14-2006, 11:15 AM
Wider is Better
wholberg's Avatar
There is a company in Europe that makes plastic inner fender guards for Porsche's and other high-end sports cars. They are pretty affordable, not including shipping. I don't have the web address on my work computer but I will find it and post it tonight.
Wider is Better
I think the problem is that the liner wouldn't completely keep the dirt from getting back there and since the liner is there you'll be less likely to clean it.
Old 02-14-2006, 11:35 AM
I hope one doesn't have to drill holes to attach this liner.....
Old 02-14-2006, 11:40 AM
DG624's Avatar
I have installed rear splash shields to my '86...the rear is the place that gets all of the dirt and gravel. The front has the oil cooler and water tank for the windshield that take up alot of debris. I would be interested in any front shields but would have to wonder if they would interfere with the oil cooler.
Old 02-14-2006, 12:09 PM
Glasgow 911SC's Avatar
Lokari
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 02-14-2006, 12:12 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
These are aluminium for the 911 and not plastic. And they do not give any indication related to how they are to be installed? I would be interested as well, if they were attached in a way that would give me the ability to remove them for cleaning periodically?? Anyone tried these on a 911, and can give us some more information on how they are attached etc?
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 02-14-2006, 01:32 PM
Tim K's Avatar
As for use as a means of reducing the amount of garbage, I wouldn't bother unless they fit extremely well. You'll probably still get some junk in behind and will require removal for proper cleaning.
On a related note (and I don't want to hijack )
I've been wondering if driving with the fenders sans undercoating means running the risk of denting them from the rocks and debris that will inevitably be fired around. Does anyone have experience here? Thoughts?
The purpose of removing the undercoating is in ongoing attempts at reducing weight. These fender wells seem like a nice idea, but may offset any benefits of the weight removal.
Tim K
Old 02-14-2006, 01:41 PM
jriera's Avatar
Send a message via AIM to jriera Send a message via Yahoo to jriera
Lokari has both platic and aluminum for 911's. Been looking for a while at those, haven't pull the gun yet. Seems that Clinton Coates CCoates@golder.com in BC Canada may have some more info.
Jordi Riera
'84 930 (modified)
Old 02-14-2006, 02:04 PM
Recreational User
porschenut's Avatar
Why use a liner? It's going to get just as dirty just as fast, so it's not going to save you from cleaning. Plus, as others have noted you'll have to remove them each time in order to clean behind them.
All you have to do is clean the wheel wells really good one time, and after that you can keep them clean very easily.
Old 02-14-2006, 04:33 PM
Wider is Better
wholberg's Avatar
Jreira had it right. The company I have a link for is Lokari. If I lived in snow country, I would put them on my car.
http://www.lokari.de/en/innenkotfluegel.php
Wider is Better
Old 02-14-2006, 04:35 PM
Something would be most helpful in the rear where there are many crevices that can hold road debris and general muck. Remove the tail light housing and see the gravel and stuff that gets thrown here. Is anyone really going to spray water behind the tail light housing to clean this area?
Sherwood
Old 02-14-2006, 06:04 PM
buster73's Avatar
Fender liners like the ones from Lokari are quite popular in Europe for cars driven during the winter months. You should clean the wheel wells and spray them with some corrosion protection wax before installing. If you drill holes they should be de-burred, primed and painted before inserting the screws. And put a drop of wax on the screws (best stainless) for added protection. Its also good idea to remove the liners once in a while to check for any problems. Not to forget that they might impact oil coolers and brake cooling, which of course is no problem in the winter time, but could be an issue if you are doing track days in the Arizona summer.
Regards,
Guenter
73.5 911T, mod
Old 02-14-2006, 06:33 PM
coolcavaracing.com
Kroggers's Avatar
I have just discovered that Lokari is a Finish company with an office in Sweden (just 2 hours north from Stockholm), so I might make a trip up to see them in the next couple of weeks.
Old 02-14-2006, 11:54 PM
Series900's Avatar
fendershields? 964's got em, n oil coolers too
and if one is drillin n screwin,you might consider larger square holes and insertion of plastic fastners for screw gripping, or plastic rivets...after corrosion protection application to the bare metal.
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 02-15-2006, 05:22 AM
Green Skull 006
Jim Garfield's Avatar
Sherwood
Oh.....I assumed everybody else did that too, am I the only one?
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 02-15-2006, 06:15 AM
