-   -   What is it and how difficult to remove?? (Pic) (http://forums.pelicanparts.com/porsche-911-technical-forum/266490-what-how-difficult-remove-pic.html)
JerDe 02-14-2006 05:39 PM
This object is stuffed under the right rear fender on my 86 930.. 2 Qs - 1. what is it?? ...and 2. how can I remove it ( is it just the one bolt that is exposed that I need to remove?) As you might be able to tell by the pic, as a winter project, I am in the process of undercoating the vehicle with POR15 and would like to remove this if not too difficult in order to get behind it properly. Of course, I will reattach it when finished. Just want to make sure I won't be asking for trouble.
Thanks ~ Jerry SmileWavy http://forums.pelicanparts.com/uploa...1139967555.jpg
jbripps 02-14-2006 06:14 PM
I hope it's not ticking......kidding. Anyhow, not sure what that is, but it seems to have some type of air flow hoses? Just a guess.
Good luck,
bigrubberjeep 02-14-2006 06:24 PM
I tlook slike the canister for the A/C system, the ones that holds the condensation. Then again it could be a charcoal canister for the smog.
efhughes3 02-14-2006 06:30 PM
Not A/C-that's the dryer in the front LH fender. Something to do with smog probably, or some kind of relief valve for vacuum system?
john walker's workshop 02-14-2006 07:03 PM
charcoal cannister.
PorscheGuy79 02-14-2006 07:05 PM
just dont eat whats inside.
Yellowbird RS 02-14-2006 07:05 PM
follow the hose and see where they go
RSBob 02-14-2006 07:14 PM
A black lab puppy? It can be easily removed with a small dog biscuit. (Since everyone is guessing... what the hike)
gerard vaglio 02-14-2006 08:14 PM
If John Walker says its a charcoal cannister, its a charcoal cannister.
JerDe 02-14-2006 08:20 PM
AGREED ! If John Walker said it is. it IS ;) I removed it and it is very light, I am sure it as a charcoal canister.. it's all cleaned up now and ready to be returned to its original place :cool: Thanks all for the timely help Jer I'll post pix after I'm done
jeff1hughes 02-14-2006 11:20 PM
I don't know if John is right this time, I think RSBob is a little closer to the correct answer.
bigchillcar 02-14-2006 11:58 PM
what he said..and what jw said.. ;)
ryan
Kroggers 02-15-2006 01:21 AM
Hi Jerry, not wanting to change from the original subject, but could you give some more details about your project? I am going to do the same job this spring, and was wondering how to get round all the stuff under the front of the car. Did you remove it all to be able to get in there, or are you just putting the POR15 round it all?? Additionally, how did you remove all the old stuff first?
kees 02-15-2006 02:02 AM
Charcoal cannister
Hi Jerry,
I've done the project already. It's realy easy to remove the cannister. Just remove the bolt from the bracket (underneath the cannister). The bracket itself sits in place with two nuts.
There might be a lot of dirt behind it, especially in the corner with the panel which holds the door striker plate.
Before:
http://forums.pelicanparts.com/uploa...1139997555.jpg
New bracket:
http://forums.pelicanparts.com/uploa...1139997665.jpg
http://forums.pelicanparts.com/uploa...1139997723.jpg
After:
http://forums.pelicanparts.com/uploa...1139997754.jpg
Kees.
SmileWavy
kees 02-15-2006 02:10 AM
Sorry, didn't see that you just figured it out.
Kees.
SmileWavy
PorscheGuy79 02-15-2006 02:53 AM
Kees.
SmileWavy
Even so thats some great looking work Kees! Nice job.
bigchillcar 02-15-2006 07:48 AM
very clean work, kees.
ryan
JerDe 02-15-2006 04:26 PM
Kroggers - I'm mechanically "challenged", so I removed only those things that I could easily remove. ( covers, spoiler attachments, etc...) and I'm painting the entire underside with a very small brush.. seems to be able to get to all the places I want to so far. I pulled the rockers and the rear bumper off also and cleaned up those areas as well. ... as far as the old stuff, I am just covering it after a thourough cleaning. 2 or 3 thin coats seems to be working nicely... I'm really happy with the way it looks.
Kroggers 02-15-2006 11:36 PM
Thank you for the info. I will probably work to remove the old stuff first, as I want to make sure there is no rust there before I put on the POR15...
