-   -   On the way to work my speedo stoped working!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/266571-way-work-my-speedo-stoped-working.html)
favrok01 02-15-2006 06:21 AM
On the way to work my tach stopped working!!!
It stopped because voltage was dropping and all the functions of my car started to go after that.
until it stopped running completely.
alternator was going but warning light was burned out so i was unaware.
finally battery died and then the power pull was to much for the already faltering alternator and it went also.
I have since replaced the bulb and am going to replace alternator at lunch then i also have a warrantied battery and will replace that when i am done.
javadog 02-15-2006 06:27 AM
It would be helpful if you told us what car you are talking about. Did the odometer quit too?
JR
jluetjen 02-15-2006 06:46 AM
It's just a sign that you're about to sell your car. Didn't you now that most of the 911's which are for sale have a speedo that recently stopped? ;)
favrok01 02-15-2006 09:25 AM
Tach that stopped on way to work
ahhhh Im sorry guys i gave all wrong info..
It was my tach that stopped and its a 83 sc
favrok01 02-15-2006 07:34 PM
update
It was my battery was dying and my alternator was going dead.
my no charge light was burnt out so i wasnt aware of what was going on.
everything at once
'76 911S 3.0 02-15-2006 07:59 PM
JR
I have a '76 911s with a 79 3.0 and this happened to me both my speedo and odometer stopped at the same time. I replaced the sender, that brought the speedo back to life, but off by 10mph, so at 0 it says 10. And the odometer still does not work. Do I need a new one?
javadog 02-16-2006 06:23 AM
You need to remove the speedometer and send it off to be repaired. The odometer fault is an internal problem and while it's being fixed, it can be calibrated and cleaned. Try North Hollywood Speedometer.
JR
