Red face On the way to work my tach stopped working!!!
It stopped because voltage was dropping and all the functions of my car started to go after that.
until it stopped running completely.
alternator was going but warning light was burned out so i was unaware.
finally battery died and then the power pull was to much for the already faltering alternator and it went also.
I have since replaced the bulb and am going to replace alternator at lunch then i also have a warrantied battery and will replace that when i am done.
Old 02-15-2006, 06:21 AM
It would be helpful if you told us what car you are talking about. Did the odometer quit too?
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 02-15-2006, 06:27 AM
jluetjen's Avatar
It's just a sign that you're about to sell your car. Didn't you now that most of the 911's which are for sale have a speedo that recently stopped?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 02-15-2006, 06:46 AM
Tach that stopped on way to work
ahhhh Im sorry guys i gave all wrong info..
It was my tach that stopped and its a 83 sc
Old 02-15-2006, 09:25 AM
update
It was my battery was dying and my alternator was going dead.
my no charge light was burnt out so i wasnt aware of what was going on.
everything at once
Old 02-15-2006, 07:34 PM
JR
I have a '76 911s with a 79 3.0 and this happened to me both my speedo and odometer stopped at the same time. I replaced the sender, that brought the speedo back to life, but off by 10mph, so at 0 it says 10. And the odometer still does not work. Do I need a new one?
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 02-15-2006, 07:59 PM
You need to remove the speedometer and send it off to be repaired. The odometer fault is an internal problem and while it's being fixed, it can be calibrated and cleaned. Try North Hollywood Speedometer.
JR
Old 02-16-2006, 06:23 AM
