checking oil
How do I check the oil in a 1972 911T?
Engine at idle after at least a 30 second run....is usually sufficient...do not over fill...typically between the lines is fine
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
I removed the cap and saw all the oil flowing about with the car running. Kind of strange way to have to grab the dip stick. Thanks
