Grip It & Rip It
I'm an electrical novice...how do I go about testing the electrical draw of the fuel pump. I want to figure out if excessive draw may have been the reason for a fuel pump relay failure. The relay heated up enough to where it melted the plastic around the female part of the socket/harness. I want to figure out if I need to replace the pump.
Thx!
82 911SC (sold) |
You need an ammeter. It would be wired inline termporarily. I would make sure your meter is capable of 20 to 30 amps, if the current is melting your relay. I'd wire it between the wire feeding the pump and the fuse block.
I'm not sure where to buy them, they are common electronics diagnostics tools. If your pump sounds funny and is melting relays, seems like a good bet that its bad. Just because it is bad, doesn't mean a new one will solve your problem, if environmental issues cause it to go bad. IE a rusting fuel tank could pollute the gas and ruin the fuel pump. Other dirt, sediment could cause the same result. Doug
1971 RSR - interpretation |
here u guys go click and save money and headache
930 Fuel Pump Fuse Overload - The Solution - Pelican Parts Technical BBS |
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
The FP has extremely inrush surge currents and so just a few milliohms at these connections will result in an inordinate level of heat at the high resistance point(s) |
