-   -   The Getty Design Flush Mount Frame Kit (http://forums.pelicanparts.com/porsche-911-technical-forum/266911-getty-design-flush-mount-frame-kit.html)
Kroggers 02-17-2006 02:21 AM
Has anyone here got any experience with these?
http://forums.pelicanparts.com/uploa...1140171675.jpg
Do they facilitate the ability to fit the 993 screens to the older style cars, and therefore also removing the rubbers? What is the fit like etc?
Series900 02-17-2006 04:02 AM
P, these are race car parts, meant for poly/lexan glazing, is your car street or track?
Kroggers 02-17-2006 04:09 AM
My car is 99% street. I was just wondering if this was a cost effective solution for getting rid of the leak prone rubber seals on the SC, and at the same time getting the more modern 993 look.
Series900 02-17-2006 04:34 AM
go with modern seals and glass
earlyapex 02-17-2006 06:16 AM
The Getty flush mounts are not water proof. They are meant for race cars.
widebody911 02-17-2006 06:45 AM
Those are not what you want for a street car
http://rennlight.com/gallery/image/5000156.JPG
Kroggers 02-17-2006 06:54 AM
OK, I see :D
84CAB 02-17-2006 08:42 AM
I am thinking about using this one from SPEKTR with my fiberglass hardtop.. My car is street only and not driven in bad weather, the guy at SPEKTR said this rear unit can be made about 99% leakproof with silicone.I'll just have to be careful when washing it.http://forums.pelicanparts.com/uploa...1140194529.jpg
randywebb 02-17-2006 01:01 PM
you could use the 964 setup IIRC some have done that on the front
it would reduce wind noise a bit also
Kroggers 02-17-2006 03:24 PM
How do you do the 964 setup?
JP911 02-17-2006 05:32 PM
The 964 setup eliminates the metal trim piece.
earlyapex 02-17-2006 06:03 PM
The Sektr flush mounted rear window is one nice unit. The price is a bit hard to swallow.
RarlyL8 02-17-2006 09:16 PM
Jack Olsen has done this treatment to BBII. Don't recall the details, check it out.
Vipergrün 02-18-2006 05:06 AM
You can use a 964 windshields and trim-less gaskets on front and rear, and you can use the 993 gaskets on your existing rear 1/4 windows. Some have tried to use the 964 gaskets with stock windshields, but I believe he windshields are a bit too small....
Kroggers 02-18-2006 05:30 AM
Cool, any one done this? And have pic's?
Vipergrün 02-18-2006 05:38 AM
No pics, but I did the 993 gasket conversion on my 80SC. Fitment was fine and it looked nice too. A search should reveal threads with the windshield conversions and pics.
strokher racing 10-29-2012 10:03 PM
Bringing this thread back up. Has anyone had issues with how well their getty design frame kit fits? I have the quarters and rear window frames.
aston@ultrasw.c 10-30-2012 12:37 PM
I recently installed the Getty frames. The "any issues" question all depends on your perspective.
If you are familiar with installing FG parts you will be pleased with the Getty frames, if this is you first experience with FG you will be pissed off!
Let me explain. FG is a brilliant process used to create all kinds of elaborate shapes for relatively low cost. The problem is that when the part is delivered to you, it is not finished. You will need to finish it before you install on your car.
"Finishing" includes grinding the flange for the correct depth, cutting the opening for a consistent width and nice round corners, filling various divots and holes in the surface due to mold damage, all over sanding and glazing. And of course
painting.
I did all this, and my car is a track rat, not a spit and polish queen!
strokher racing 10-30-2012 04:59 PM
Hey Aston can you PM your email? I was wanting you to check out a pic of something if you could?
aston@ultrasw.c 11-26-2012 05:20 PM
OK...I finally got around to taking some pics of the final product...
http://forums.pelicanparts.com/uploa...1353979150.jpg
http://forums.pelicanparts.com/uploa...1353979171.jpg
http://forums.pelicanparts.com/uploa...1353979187.jpg
http://forums.pelicanparts.com/uploa...1353979205.jpg
http://forums.pelicanparts.com/uploa...1353979219.jpg
