ok. after I found that my '74 Carrera have the M calipers (3" struts) I made a litle research and found some calipers upgrades
1.- the classy BMW 2.- the 4 pistons Volov 3.- the mazda RX-7 turbo 4.- for 944turbo/964, 993, Big red WHAT DO YOU THINK??? feedbacks, PROS/CONT
X/A Last edited by Yellowbird RS; 02-19-2006 at 05:04 PM.. |
Your 74 Carrera should have S calipers and 3.5 inch spacing. Was your suspension back dated at some point?
1973 911T Sepia Brown MFI 1986 Carrera Meteor Gray Metallic |
I would rather be driving
I think VCI makes adapters for 3" struts. Call and ask. It is just a matter of drilling holes on a different spancing. this would allow you to use any of the radial mount calipers.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
If it was my car I would buy some 3.5" struts, then the whole world of brake upgrades(including their associted rotors) opens up for you, remember that unless the rotors are upgraded it's not a real upgrade.
Hi Bill:
Hmmm,...I'm not so sure,... ![]() I bought my '74 Carrera new (which I still have) and it came with "S" struts as standard. Even my '74 factory brochure says that "S" brakes are standard on the Carrera,..........
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Take a look in PET or Frere 6th ed. p356
'74 US Carrera cis used M f/r
I think that might be an error in the PET :>)
My old window sticker said "S" brakes were standard and as I ordered this car, I didn't pay extra for them,.....
![]() PET is not always the last word on things,........
993s are supposed to have engine mounted oil filters, there are lots of cases of anomalous parts.
IIRC he measured the mounts at 3", Even posted a pic. I don't believe that PET is wrong in this case
I can believe that some came one way and some another
Never seen one with Boge's from the Factory.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com Last edited by Steve@Rennsport; 02-19-2006 at 08:48 PM.. |
Maybe Yellow Bird can post his VIN? I'm real curios if he's even got a Carrera. It should have a front sway bar too, which would be visible in the photo he posted.
According to my title it's a Carrera US CIS 2.7
VIN 9114 400431 color 936 VW silver Metallic AND I HAVE THE 3" STRUTS w/M CALIPERS FRONT & REAR
X/A Last edited by Yellowbird RS; 02-20-2006 at 10:10 AM.. |
911 440**** is definitely a '74 G series US Carrera
My advice is the same regardless, get the 3.5" struts and go from there choices are; Carrera 930 964 993 GTP-L GTP
I agree with that advise Bill. 3.5 inch struts and A or S calipers. Keep it Porsche. You'll have less trouble than if you try to develop your own brake system.
Interesting on the lack of front swaybar and S calipers. My Carrera is # 404 so it's close in production to Yellowbirds. It's always had S calipers, Bilstien 3.5 inch struts and the front sway bar. I've got the original invoice and none of these items are listed as an option but the "rear spoiler" is. Weird.
X/A |
But look at it this way, struts don't last forever, I replaced my Bilstein inserts twice and the lower part(w/ the ears) once in a little more than 100k miles.
