Me like track days
Craig 930 RS's Avatar
Question G50/50 -- changing 5th gear - what does it 'take'?
Currently I hit redline at the track with the 5th I have in the G50/50. Nothing like a rev limiter cutout in mid-turn
What is involved in changing 5th gear in a G50/50 transmission?
Thanks in advance - !
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-21-2006, 12:02 PM
Friends of Warren
911teo's Avatar
U talked to Paul Guard? Geary on this board
1 530 878 4499
Matteo
Warren RIP
www.impactbumpers.co.uk
Old 02-21-2006, 12:07 PM
don911's Avatar
What turn are you hitting the limiter in 5th gear? If we're ever at the track same day, remind me that I really don't want a ride in your car.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 02-21-2006, 12:08 PM
Me like track days
Turn 1........ "the turn that kills" ;-)
Right around 150 I have to glance at the tach.
Just spoke with Paul - it is a pretty easy job - have to take out the transmission, and 5th and reverse come out together. About $695 for the pari of gears.
Old 02-21-2006, 12:22 PM
Bill Verburg's Avatar
Be careful, a change in one gear will lead to an avalanche of others to keep the splits in line.
Bill Verburg
Old 02-21-2006, 02:32 PM
Me like track days
Luckily the 4th to 5th split is shorter than the rest and lends itself to a higher gear -
Old 02-21-2006, 02:42 PM
Here're your stock splits as a %
43% 29% 24% 22%
You want the % to decrease as you go up through the gears. If 5th is made much taller it increases the %
You have a ton of torque so can handle bigger splits than a n/a engine but there is still a limit.
a good n/a box might look like this
50% 21% 14% 11%
Bill Verburg
Old 02-21-2006, 02:55 PM
Me like track days
Bill -
What should I use for a new 5th?
Looking for another 15-25 mph or so:
Old 02-21-2006, 04:10 PM
The trans has already been regeared according to that chart.
If it is correct your 5 is the stock 4. That would be the source of your problem.
what tire height and rev limit are you using?
Bill Verburg
Old 02-21-2006, 08:10 PM
Send a message via ICQ to Terrh
Perhaps changing the final drive ratio would be a better (easier) process?
Old 02-21-2006, 08:34 PM
Yeah, hitting the rev limiter in a stock G50/50 shouldn't happen at 150. That's a tall gear, stock.
150 at turn 1 is smokin' pretty good, I'll give you that.
Old 02-21-2006, 11:48 PM
Here's the splits w/ that box
 g50.50			41	35	30	40	29
modified short 13 17 19 33 30
3.15 2.06 1.58 1.21 0.97
3.444 10.86 7.09 5.44 4.17 3.33
split % 35% 23% 23% 20%
speed @6800 47 73 95 124 155
the above is w/ a ~25.7" rear tire, taller gives you a couple of mph in each gear
Bill Verburg
Old 02-22-2006, 06:09 AM
Me like track days
Does this help - a better view of the charts?
Old 02-22-2006, 10:46 AM
No, that is the information I used in my last post
here is what a stock G50/50 looks like
g50.50			41	34	33	29	31
13 19 26 30 41
3.154 1.789 1.269 0.967 0.756
3.444 10.862 6.163 4.371 3.329 2.604
split % 43% 29% 24% 22%
speed @6800 47 84 118 155 199
Bill Verburg
Old 02-22-2006, 11:36 AM
Me like track days
Right, giving a closer view in case it was hard to read.
So Bill, what would you use for 5th gear?
Old 02-22-2006, 11:43 AM
Craig, that's not going to be as easy as swapping out 5th
If you only change 5th to something like 24:29(0.89) 170mph top speed then the split to 5th becomes 27% w/ an rpm drop of ~1800. That's pretty ugly
So then you need to redo 4, w/ the same result etc. etc.
As I said a cascade of gears is needed.
I would probably want the factory w/ a little shorter 3,4,5
I started to fiddle w/ some gear charts but another out side project is needing my attention. I'll continue later.
Bill Verburg
Old 02-22-2006, 01:56 PM
Me like track days
Currently, the RPM drop from 4th to 5th is 1,372 -- subjectively it could really stand about a 500 increase.
Thinking out loud:
So with the Turbo I'd shift at 6,300, dropping the rpm to 4,500 instead of 5,000 at the 5th gear change with the 24/29 set.
Appreciate the number work, Bill. I'm a neophyte with gearing.
Old 02-22-2006, 02:33 PM
Me like track days
She's still pretty healthy at 4,500...added this for reference
Gears are almost the only thing I've been thinking about all winter
I've got gears coming out my ears
Ok, so if I run some #s, 6300 rpm shift point? either the height or revs/ mile(better) is also needed. I've been using 6800 and 25.7" tire
Bill Verburg
Old 02-22-2006, 02:58 PM
Oh and the max rpm drop you would be comfortable w/
from the dyno charts I would say 1000rpm
Bill Verburg
Old 02-22-2006, 03:00 PM
