Cheep way to more HP in early 911T
I’m looking for an cheep way to get 10-40 HP more, out of my 2.0 911T from 1969. Any suggestions? What about reliability? And is it wise to do on a daylily driver
Old 02-22-2006, 12:20 AM
Warren Hall Student
Bobboloo's Avatar
I don't think there is really a cheap way to add horsepower to that motor. Most cheap horsepower comes from intake or exhaust improvements. The intake and exhuast on your car are capable of much more power when placed on a bigger motors so no big gains there.
You could get a couple horses maybe with a sport muffler but more than likely it would only show on a dyno at redline and it might come at a cost to driveability. You could find yourself with some deadspots in the RPM range. In short the car won't feel faster and it will be noisier.
This means making any real gains will have to come from the bottom end and that's expensive.
Basically the cheapest way to get more horsepower for your car is to buy a bigger motor and swap it. Modifying your motor will cost substantially more and produce less than a swap.
Sometimes you can find decent 2.4 or 2.7s for $2500 or less. A decent 3.0 will usually cost $3000 and up.
The cheapest way by far to go faster is not with horsepower. It's by lightening your car. Anything that isn't necessary can be removed.
One more thing you might want to consider. If your car is a nice original example in good condition you can sell it and buy a not so original car with a bigger motor. There are cars out there that have had their motors swapped for bigger ones and they are usually a bargain. I bought one of these cars, a 73' with an 87' Carrera motor, for roughly what you would pay for one with a stock 2.4. Possibly even less. I couldn't be happier.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 02-22-2006, 02:17 AM
cycling has-been
bkreigsr's Avatar
try a full service. new plugs, points, dizzy cap, condenser, plug wires, reset timing, tune carbs to spec, clean/renew air filter elements, fuel filter, new filter screen in the gas tank, fresh oil in motor and trans, and vacuum lines.
you are going to be amazed!
bill k
Old 02-22-2006, 06:09 AM
KillerDynoSoar's Avatar
Or do what Colin Chapmans suggests and 'add' lightness. IE Strip that sucker out a bit.
Also I know this sounds silly but drive your car to the redline as it was supposed to be driven. A few Porsche guys don't do this and never realise the full potential of their car.
After reading some of the comments on here on how you drive your P car and trying it myself, its an amazing difference. I have had too much mechanical sympathy to do this before.. but thats how you drive them and they are amazing cars. I have a friend who has an acurate RS clone (getting fia papers for it) and he tried it and was astonished at the performance level.
77 Porsche 911 3.0 Carrera
58 Porsche 356
55 Chevy Bel-Air
72 Volkswagen Bug, 06 Volkswagen T5
14 Yamaha R1, 14 GSXR750, 17 CRF1000
Old 02-22-2006, 06:39 AM
Autodidactic user
David E. Clark's Avatar
That's the key. Check out this site for some tips.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 02-22-2006, 07:51 AM
}{arlequin's Avatar
40hp would cost you $4-5k.... better to buy a whole sc or 3.2 motor
dave
1973,5
Old 02-22-2006, 07:55 AM
bigchillcar's Avatar
no cheap hp..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 02-22-2006, 09:10 AM
3 restos WIP = psycho
kenikh's Avatar
You might get 10 HP cheap, but 40 HP is going to cost you a new set of pistons and cylinders, plus head work and cams. If you go used, you might be able to get:
used 2.2 'E' or 'S' pistons and cylinders = ~$1000
headwork (chamfer, porting) = $125/head (you could reduce this by deleting porting)
used 'E' cams = ~$250
This could yield near 150 HP at the crank and a much better powerband. So if you are diligent and do the work yourself, you could get a really snotty little motor for around $1200 - $2000, plus the cost of cam tools (another $100 - $150).
Is that cheap? In Porsche dollars, yeah, it is.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 02-22-2006, 09:34 AM
good advice, kenik..likely as economical as it's gonna get..in porsche $$$, that's coming out pretty.
ryan
Old 02-22-2006, 09:39 AM
Early_S_Man's Avatar
Porsche Crest
You guys are forgetting about the 'Rallye' engines based on 'T' heads and 'S' cams and carburetion ... 150 hp DIN @ 2.0 liters ... use the 2.2 'S' p & c set suggested by kenikh and 'S' cams gets you at least 160 hp DIN ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-22-2006, 09:58 AM
kenikh's Avatar
I had indeed forgotten about that motor. Good call on keeping the T heads stock. Used 'S' cams are more expensive than 'E' though.
I wonder, could 2 liter 'S' pistons be used reliably in the iron 'T' cylinders? I think so. This setup would be about $500 for the pistons and another $350 - $400 for used 'S' cams. This should still result in a DIN 40HP gain and much more fun powerband. Less than a grand in parts? Now THAT is cheap.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 02-22-2006, 10:05 AM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
If your 69T is still using the stock ignition, replace it with an MSD unit. Also replace the cap, rotor, wires, coil and plugs with something that works better with the MSD. You could tweak a little more HP out of your engine that way. It should start and idle better, at least.
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 02-22-2006, 10:22 AM
Sports Purpose 911 Driver
mjshira's Avatar
as others have said, drop lbs off the car.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 02-22-2006, 10:39 AM
kenikh's Avatar
This advice comes from a guy who runs a 3.6?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 02-22-2006, 10:41 AM
(the shotguns)
berettafan's Avatar
Aren't there differences in the crankshafts of T's vs. E & S?
I seem to recall something about balancing or such.
Erik
(sorry if this is a dumb Q; just a newb trying to keep everything straight in his head)
Old 02-22-2006, 10:52 AM
kenikh's Avatar
Good point. Yes, the 'S' and 'E' have counterweighted cranks, the 'T' does not making an unmodified 'T' crank less reliable for long term high RPM usage. This is why I was advocating the 'E' cams as you don't have to keep the revs up as high to keep it in the powerband. The rally car used the 'T' crank (with 'S' cams) which is lighter and thus spools up faster, but it was a race car that had regular tear downs between races.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 02-22-2006, 11:03 AM
