Me like track days
Currently I hit redline at the track with the 5th I have in the G50/50. Nothing like a rev limiter cutout in mid-turn
What is involved in changing 5th gear in a G50/50 transmission? Thanks in advance - !
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Friends of Warren
U talked to Paul Guard? Geary on this board
1 530 878 4499 |
What turn are you hitting the limiter in 5th gear? If we're ever at the track same day, remind me that I really don't want a ride in your car.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Me like track days
Turn 1........ "the turn that kills" ;-)
Right around 150 I have to glance at the tach. --------- Just spoke with Paul - it is a pretty easy job - have to take out the transmission, and 5th and reverse come out together. About $695 for the pari of gears.
Be careful, a change in one gear will lead to an avalanche of others to keep the splits in line.
Me like track days
Luckily the 4th to 5th split is shorter than the rest and lends itself to a higher gear -
Here're your stock splits as a %
43% 29% 24% 22% You want the % to decrease as you go up through the gears. If 5th is made much taller it increases the % You have a ton of torque so can handle bigger splits than a n/a engine but there is still a limit. a good n/a box might look like this 50% 21% 14% 11%
Me like track days
Bill -
What should I use for a new 5th? Looking for another 15-25 mph or so:
The trans has already been regeared according to that chart.
If it is correct your 5 is the stock 4. That would be the source of your problem. what tire height and rev limit are you using?
Perhaps changing the final drive ratio would be a better (easier) process?
Yeah, hitting the rev limiter in a stock G50/50 shouldn't happen at 150. That's a tall gear, stock.
150 at turn 1 is smokin' pretty good, I'll give you that. |
Here's the splits w/ that box
g50.50 41 35 30 40 29the above is w/ a ~25.7" rear tire, taller gives you a couple of mph in each gear
Me like track days
Does this help - a better view of the charts?
here is what a stock G50/50 looks like g50.50 41 34 33 29 31
Me like track days
Right, giving a closer view in case it was hard to read.
So Bill, what would you use for 5th gear?
Craig, that's not going to be as easy as swapping out 5th
If you only change 5th to something like 24:29(0.89) 170mph top speed then the split to 5th becomes 27% w/ an rpm drop of ~1800. That's pretty ugly So then you need to redo 4, w/ the same result etc. etc. As I said a cascade of gears is needed. I would probably want the factory w/ a little shorter 3,4,5 I started to fiddle w/ some gear charts but another out side project is needing my attention. I'll continue later.
Me like track days
Currently, the RPM drop from 4th to 5th is 1,372 -- subjectively it could really stand about a 500 increase.
Thinking out loud: So with the Turbo I'd shift at 6,300, dropping the rpm to 4,500 instead of 5,000 at the 5th gear change with the 24/29 set. Appreciate the number work, Bill. I'm a neophyte with gearing.
Me like track days
![]() She's still pretty healthy at 4,500...added this for reference
Gears are almost the only thing I've been thinking about all winter
I've got gears coming out my ears Ok, so if I run some #s, 6300 rpm shift point? either the height or revs/ mile(better) is also needed. I've been using 6800 and 25.7" tire
Oh and the max rpm drop you would be comfortable w/
from the dyno charts I would say 1000rpm
