-   -   Horn problem / steering column bushing (http://forums.pelicanparts.com/porsche-911-technical-forum/268260-horn-problem-steering-column-bushing.html)
kees 02-24-2006 12:37 PM
I've got a problem with my horn ('85 911 coupe). It will work when the steering wheel is straight and the car is standing still. Whilst driving it isn't. Now I've read somewhere that replacing the plastic bushing in the steering wheel column for a metal one can fix the problem.
Is there somebody who can confirm this?
BTW I've no problems at all with the steering(wheel) itself.
http://forums.pelicanparts.com/uploa...1140812638.jpg
http://forums.pelicanparts.com/uploa...1140813409.jpg
Thanks,
Kees.
SmileWavy
kees 02-26-2006 12:00 AM
Bump.
Thanks,
Kees.
SmileWavy
Nine9six 02-26-2006 06:04 AM
Try raising the metal contact for your horn...It is the metal piece at the top of your photo. Do this a little at a time.
kees 02-26-2006 06:27 AM
Horn
Nine9six,
I'll try this.
Thank you,
Kees.
SmileWavy
Howard M 02-26-2006 07:29 AM
Also, clean and polish the brass circular disk on the back of the steering wheel, that the horn contact blade wipes.
JP911 02-26-2006 07:46 PM
I had the exact same problem and installing the metal sleeve/bushing solved it. It also improved the steering feel. With the steering wheel already off, it's about a 5 minute job to hammer in the sleeve. I used a large socket that fit over the steering shaft, and lined up with the sleeve, and then hammered it in.
kees 02-27-2006 08:18 AM
Horn / steering column bushing
Thank you all.
Kees.
SmileWavy
