911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest Horn problem / steering column bushing
I've got a problem with my horn ('85 911 coupe). It will work when the steering wheel is straight and the car is standing still. Whilst driving it isn't. Now I've read somewhere that replacing the plastic bushing in the steering wheel column for a metal one can fix the problem.
Is there somebody who can confirm this?
BTW I've no problems at all with the steering(wheel) itself.
Thanks,
Kees.
Old 02-24-2006, 12:37 PM
kees's Avatar
Porsche Crest
Bump.
Thanks,
Kees.
Old 02-26-2006, 12:00 AM
Nine9six's Avatar
Try raising the metal contact for your horn...It is the metal piece at the top of your photo. Do this a little at a time.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 02-26-2006, 06:04 AM
kees's Avatar
Porsche Crest Horn
Nine9six,
I'll try this.
Thank you,
Kees.
Old 02-26-2006, 06:27 AM
Also, clean and polish the brass circular disk on the back of the steering wheel, that the horn contact blade wipes.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 02-26-2006, 07:29 AM
I had the exact same problem and installing the metal sleeve/bushing solved it. It also improved the steering feel. With the steering wheel already off, it's about a 5 minute job to hammer in the sleeve. I used a large socket that fit over the steering shaft, and lined up with the sleeve, and then hammered it in.
Old 02-26-2006, 07:46 PM
kees's Avatar
Porsche Crest Horn / steering column bushing
Thank you all.
Kees.
Old 02-27-2006, 08:18 AM
