-   -   Anyone ever try modifying stock sways? (http://forums.pelicanparts.com/porsche-911-technical-forum/268294-anyone-ever-try-modifying-stock-sways.html)
bigrubberjeep 02-24-2006 04:19 PM
I was over at Andial today and saw what they call "toy car"
To keep it short I'll just say that it was the best representation of a "toy car" I have ever seen with about 75K put in to it.
911 body (unknown year)
3.2 convereted to 3.5 with 991HE and a custom exhaust
bilsteins all around with big reds
this car was so clean you could eat off it.
Anyhow back to the question, the rear sway bar they had was a OEM sway but it had a couple of extra holes drilled on to the pick up point for the drop links, this way it becomes in a sense, an adjustable sway.
Anyone ever dones this? What was your experience?
johnsjmc 02-24-2006 04:38 PM
I have done it on an 86 style rear with the flat side flange and bolt on drop link. The spring steel is hard to drill. You use a carbide tip concrete drill and grind the end to match an ordinary drill bit.I don,t think I can feel a difference but there must be some increased stiffness because of the approx.1 inch shorter arm.
