Who sells EGT guages sensors/which are best for 3.2 Turbo Motec applications?
Motor has not gone to machine shop after intial inspection cleaning. 3.2 heads going in for twin plug next. I am jumping into design and control of EGT mgmt. Thank You. Regards
Bernard |
why dont you just use the motec thermocouples?
Excell Racing Boca Raton fl |
ssetek. I guess I need a Motec list next
Bernard |
i have a pdf of motecs catalog
Aircraft Spruce has a cool selection of EGT guages, sensors and other EGT paraphenalia.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
The coolest EGT/CHT monitor ever (IMO):
www.jpinstruments.com/edm_700.html www.jpitech.com/edm700.htm (can also add TIT, OAT, MAP, RPM, Oil temp, Volts, etc.) A few more practical ones: www.aircraftspruce.com/menus/in/egtgauges.html Little over an hour to go on this bad boy: |
