need my turbo header modified-who does the good work
l bought some B&B 930 headers for 3.2 conversion and they`re not working out.l think the turbo has to sit higher to allow the oil to drain into the cam cover properly. l believe cutting the mounting plate off and extending the collector up 1 1/2" should do it.l`m using a split volute Garrett and l`ve got a new mounting plate for it. anyhow l may try a local guy but my luck has been spotty with non Porsche people doing work like this.any help appreciated..
my life begins at 150MPH |
What did you decide to do? Pics of what you discovered/resolved?
Regards,
Bernard |
As a quick solution, you can buy a TiAL T3-T4 Flange Adapter, which would be approx 1" thick. That will mount the turbo just high enough to gravity drain into the chain cover.
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
If your fabricator can use your flange, have the turbo (and stub tube onto the header) in place in the engine bay "Just the way" it needs to be and have him TACK weld it. Check one more time , don't forget positioning of the compressor outlet, oil in/ oil drain and muffler outlet positioning-- then he can remove the tack- welded- structure and properly mig or tig weld it on the bench. Before running, make sure all the welding slag is evacuated from inside the tubes.
my $.02 Marty
Porsche builds the 21st century 9146 so easy...even a Cayman can do it ! |
...or if you can "Tack weld " the mod together Exactly how you want it, ship it over to our plant and we will finish it for you.
This of course would be at the hefty price of ; shipping charge only, no worries-we do this mod all the time ! Sample of 934 single turbo style attached ; ) PM me if interested. Marty
Any updates on this?
Rick, perhaps there's a version of this adapter/spacer to solve your problem. I believe Greddy makes high quality adapters and spacers as well.
Warren & Ron, may you rest in Peace. Last edited by RickM; 03-02-2006 at 12:16 PM.. |
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
