Bilstein/Boge insert questions
Two questions:
When I opened the Bilstein box there was a rubber ring that goes over the shaft or strut rod. About 1/8th to 3/16ths thick. Does it go under or on top of the dust shield, or does it go elsewhere? Where can I get one of the wrenches used to tighten the ring that locks the insert into the strut? I'm sure there are other ways to do it, but I wouldn't mind having the wrench. Thanks. |
The search will work wonders: http://forums.pelicanparts.com/showthread.php?s=&threadid=256927&highlight=strut+ and+wrench
In answer to your question: Cut and pasted from the link RickM supplied.
The Bilsteins come with a small rubber ring fitted around the shaft to keep the cover in place during shipping. You will not be using this in the install, so just throw it away. |
| All times are GMT -8. The time now is 01:30 AM. |
