-   -   HELP removing DME relay (http://forums.pelicanparts.com/porsche-911-technical-forum/268997-help-removing-dme-relay.html)
bfegan 02-28-2006 01:31 PM
I want to remove my DME Relay (88 Carrera). How does it come out?
I have removed the nut... is there a connection plugged into the rear (engine side) which snaps off? Can't see back there.
Thanks.
bfegan 02-28-2006 01:47 PM
I think there is a plug in connection in the rear. It doesn't come off easily and I don't want to break something. Should I just "tug harder"?
smstcoach 02-28-2006 01:51 PM
I just had to replace mine on the road today. Yes, there is a connection on the engine end of the relay. I typically take my seat out to make things easier. Good luck and don't forget to put a spare in your car!
ZOA NOM 02-28-2006 01:52 PM
I reach my right arm under the seat from behind, and my left arm under the front. I can just reach both halves of the relay/connector. Slowly rock it back and forth to separate.
bfegan 02-28-2006 01:56 PM
I'm not certain my arms are long enough. I'll go try.
Thanks!
bfegan 02-28-2006 02:02 PM
ZOANAS is the winner! I got it.
Thanks a lot.
ZOA NOM 02-28-2006 02:11 PM
Another satisfied customer. Well done, and remember to put an extra in the glove box.
mede8er 02-28-2006 03:45 PM
Zo.....
I read "slowly rock it back and forth"...then I look at your avatar...
t
Then I forget the question..........:D
