Chain Tensioner Line Replacement - Help
My left carrera chain tensioner oil line started to leak. Here it is:
http://www.pelicanparts.com/techarticles/911_Carrera_chain_tensioners/pic13.jpg
Just received the part from our host, including the 2 seal washers, and I am about ready to replace the line. Do I need to drain the oil? Will the oil start oozing out in much quantity?
Feedback please! Tips and tricks! And yes, I did read the tech article but it is missing the torque #'s.
Thanks.
BTW, the line started to leak by the rubber piece. I just don't understand why Porsche did not make 2 support brackets (I only have one). I suspect vibration finally cracked the rubber.
Old 03-01-2006, 05:14 PM
No need to drain the oil. You will get minor seepage but nothing to worry about.
Kevin
'79 Coupe
Old 03-01-2006, 05:46 PM
Thanks. Seepage was a worry, but I probably could have handled.
If the line were 'pressurized', I probably would have freaked-out!
Old 03-01-2006, 05:50 PM
the new left line usually requires replacement of the metal tensioner line also, because the threaded joint is in a different place on the new line. (the metal line has been updated.) in a pinch, you can tweek the metal line to fit.
206 637 4071
Old 03-01-2006, 06:43 PM
Hmmm..... I just went outside and without disassembly, I put them side by side and they seem to be the same. The threaded joint seems to be at the same place also.
However, the difference is that my leaky one has a cloth covering the rubber piece, whereas the one from Pelican is all rubber (no cloth). Maybe, I should just start the project late Friday, so that if I needed the metal tensioner line, I could buy it Saturday morning.
I guess I would need to remove the distributor, huh?
Old 03-01-2006, 06:59 PM
distributor out, yes. put the pulley on TDC #1, which puts the distributor rotor pointing toward the fan housing and above a notch on the top edge of the distributor body. remember the position of the rotor. mark a scribe line at the distributor base and onto the engine case that can be matched up again later and yank it. easy to reinstall now and the timing won't change if you do the lineup right.
206 637 4071
Old 03-01-2006, 07:26 PM
