#29 SCWDP (muhaahhh!!)
Gene Wilkes's Avatar
Porsche Crest STUCK h4 headlite trim ring
The trim ring refuses to come off!! Any suggestions? I don't want to force it. HELP!!!
IslandmanFL
SOLD...78 911SC (ROW) cabriolet/widebody
hear BEBE purr!!
92 325is
Now living in Sunny West Palm Beach FL!
Old 03-03-2006, 11:04 AM
She/Her
BeauBlues's Avatar
Please explain more. Are just taking the assembly off the car or are you trying to disassemble the headlight itself?
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 03-03-2006, 11:08 AM
mschuep's Avatar
Sometimes they do that. Try twisting rather than pulling. It can take a lot of force, be careful, and apply force with both hands and it should come.
edit: this worked on stock sugar scoop configuration
-Matt
1985 Targa
Old 03-03-2006, 11:13 AM
replacing burned out bulb. I realize these rings have a lip on the top, so lifting from the bottom should release it, but it won't budge......
IslandmanFL
hear BEBE purr!!
92 325is
Brad01mc's Avatar
Hi!
Off the car, or off the assembly?
If off the car, there are two "slots" @ about 4-5 & 7-8 o'clock that you should be able to use as leverage points. I'm in the middle of painting mine, so I just ran into a similar problem. When I stuck a screwdriver into the slot and began to lightly pry, it just popped out. It seems like the lip of the ring holds onto the lip of the fender. I'm not sure if this is 100% right, but it seemed to work for me.
If you're talking about getting the ring separated from the assembly, you need to remove the little wire "springs" on the back of the unit...(you can see the clips in this post by
imcarthur)
H4 trimrings
Anyway, you need to push one of the ends down to release the clip. I have absolutely no idea how I'm going to get it all back together, but I'm hoping the pictures in that post help!!
Anyway, look for the slots, or remove the "springs" and you should be OK.
If I remember to take pics, I'd like to document how to get the clips back in place.
Good luck!
Brad
'78 911 SC
'61 Mercedes 220b
'74 Westy 2.0
Old 03-03-2006, 11:18 AM
jevvy's Avatar
From what I remember you need to press down on the top to provide more room at the bottom to pull it off, palm on top pressing down and fingers underneath pulling out - hope this helps a little
'89 3.2/3.6 coupe
Old 03-03-2006, 11:20 AM
wcc wcc is offline
wcc's Avatar
Use a pick with a 90 degree head on it and stick it in the bolt hole. As you push down on the top and pull that pick from the bottom, it should pop right off.
Good Luck..
Bill
997.2
Old 03-03-2006, 12:12 PM
Thumbs up
GOT IT!!!!!!!
IslandmanFL
hear BEBE purr!!
92 325is
Old 03-03-2006, 12:40 PM
