busteif's Avatar
Big Red Kit Upgrade?
I need some help on an upgrade for a 1976 - 930 Turbo. currently the brakes on the car are good but not for the power this thing has. the current tire/wheel size are
front - 205/50/vr15
rear - 285/40z/r15
the wheels are custom made and I would hate to lose them. anyone out there that has upgraded the brakes on an older model 930 please feel free to either pm me or list the steps I have to take to do so.
all feedback is appreciated
thanks.
Old 03-06-2006, 02:19 PM
I would rather be driving
jpnovak's Avatar
I assume your early 930 has the stock aluminum "S" calipers up front and M calipers in the rear. What is the problem withthe brakes? Are you tracking the car? If so, they are probably inadequate. for street use they should be fine when properly setup (pads) unless the car has been modified.
Big reds will not fit under 15 or 16" wheels. your best bet would be a later 930 setup. (78-89)
Old 03-06-2006, 02:31 PM
JamesHamm's Avatar
There is also another option using Kieth Alexanders set up if cost is an issue. He runs Boxermotorsports and the kit is very strong and the price is impossible to beat. You can contact him at: ka911@charter.net
RenegadeHybrids also offers a kit that does not require adapters. You can read their press release here: http://www.renegadehybrids.com/pr/pr2_7.html
I'm not a brake expert but just thought I'd throw these out there.
James Hamm "Top"
First Sergeant
U.S. Army Hunter Army Airfiield
1980 911 SC (400hp)
james.r.hamm@us.army.mil
Old 03-06-2006, 03:09 PM
I think jerry st germaine had a set up for sale that may work
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 03-06-2006, 04:57 PM
Jeff Alton's Avatar
Later 930 brakes are the answer to your problem....
Cheers
www.turn3autosport.com
Old 03-06-2006, 07:23 PM
Jeff Alton's Avatar
Of course if you want to move to a 17 inch wheel, you can always use a set up like this....
cheers
Old 03-06-2006, 07:29 PM
Bill Verburg's Avatar
'78-80 930 fits but there are issues
This is a 930 setup on an RSR
Note the proximity of the rim to the caliper
In extreme situations the heat is transfered to the bead causing the tire to fail in that area, for normal use not an issue, but something to think about.
as an aside, those are pretty skinny front tires, if going to turbo brakes definitely think about some more meat up front
Bill Verburg
Old 03-07-2006, 02:37 PM
busteif's Avatar
Upgraded brake kit
This is an awsome forum, getting the feedback and knowing that someone is always ready to assist & help is a truly comfortable feeling. escpecially to those of us that just took the leap and became first time Porsche owners.
Thanks all.
Old 03-07-2006, 04:41 PM
