-   -   2.4 W/ 2.2 High Compression Mod (http://forums.pelicanparts.com/porsche-911-technical-forum/270271-2-4-w-2-2-high-compression-mod.html)
daepp 03-07-2006 11:10 AM
Has anyone every dyno'd a 2.4 modified with higher compression 2.2 P &C's? If not, any predictions. Stock mfi setup.
Now, how about a 2.4 w/86mm P&C's (now a 2.5 I suppose!) with GE40 cams and ported heads. Any dyno or estimated results as to HP gain over the previous setup?
Engine is being built as we speak. It's pathetic - I am like a kid who can' wait for Christmas day to come.
Thanks.
arrivederci 03-07-2006 11:43 AM
I have a 2.4T that I think has been modified with 2.2S P&Cs.
See the following link. Rear wheel horsepower is shown.
Dyno Sheet
jluetjen 03-07-2006 11:43 AM
I wouldn't expect the Hi-CR 2.4 to really make a whole lot more HP then a regular 2.4 -- something a little bit less then the % increase in CR. I would expect it to have a flatter torque curve though.
As far as a 2.5, without looking at my numbers (I don't have any benchmarks for the GE40 cam), but I'd guess it would be just shy of 200 HP or so.
daepp 03-07-2006 11:50 AM
Dyno Sheet
My 2.4 had 2.2 T P&C's, and it seemed quite a bit better than stock 2.4 T - I would have guessed 150-160. Others who drove it seemed to think it was quite strong for a T. Unfortuantely, it smoked like chimney, and now Supertec is rebuilding it.
daepp 03-07-2006 11:51 AM
I certainly hope you're right.
kucharskimb 03-07-2006 11:53 AM
i have a 2.4E made from a 2.2E. i use webers, not mfi.
on separate occasions and separate dynos, i have ranged between 165-172 Hp at the wheels.
http://forums.pelicanparts.com/uploa...1139345047.jpg
the labels on the dyno are jetting sizes, not hp numbers. see upper left for Hp.
http://forums.pelicanparts.com/uploa...1095049856.jpg
you can also look up my callsign for more info...
good luck.
bavaria911 03-08-2006 02:50 AM
If your motor is with Henry, did you ever think to ask him? He can surely tell you within 5-10 HP.
Vr,
Bavaria911
daepp 03-08-2006 03:04 PM
I did ask Henry and he concurred - what I was more interested in was the "before" picture", which I never had. The engine was rebuilt by a prior owner. He attempted to increase output by raising the CR w/ the 2.2 P&C's. However, he never dyno'd the car, and neither did I. Then it smoked so bad that off it went to Henry.
Cire 03-10-2006 01:51 AM
How do you get to a 2.5 configuration?
I know to get to a 2.2 / 2.4 with;
Case = 2.2
Crank = 2.4 / 2.7
Pistons = 2.2 Es
Cylinders = 2.2
Cams = E
Fuel Deliver = MFI or Carb
Heads = 2.2
New Disp = 2.4L
Compression 10:1
But the 2.5... How is that achieved and what are the goods and bads to either of these configurations?
Thanks everyone.
Eric
jluetjen 03-10-2006 05:19 AM
If you go with a 1mm overbore (85 mm's ) on the P&C's you'll wind up with a "2.5".
bkreigsr 03-10-2006 05:37 AM
my 2.5L (actually 2,481cc) was pushing 205+ (flywheel) with 10.37:1CR courtesy of Mahle 86mm pistons, cams and mfi, mods
you are gonna like it!
Bill K
Cire 03-10-2006 05:38 AM
Bill,
What type of components did you use? Crank, Pistons, Cams, etc?
How do you like the performance? Is it a short stroker.
Thanks for the help.
Eric
bkreigsr 03-10-2006 06:25 AM
crank is stock 2.4L, pistons and cylinders, as mentioned, are Mahle 86mm (ala 908), cams are Elgin custom grind, mfi reworked by H&R, Long Island, heads by Ray Litz @ Competition Engineering, ported & flowed, and a bunch of trick stuff like forged rockers, Carillo rods, light-weight wrist pins, sodium filled valves, gutted muffler (2in- 1out), etc, etc.
performance is nice. able to chirp the rears on the uphill after the toe of the boot at the Glen on the 3-4 shift, while I'm doing all my passing.
limiting factor on the car is the wheels and tires. I never did the flare thing and run a 16x6 w 205-55 tire.
http://forums.pelicanparts.com/uploa...1142000645.jpg
Cire 03-10-2006 06:29 AM
SWEET CAR!!! I love it. = ) I love that engine. Its MFI not carb?
Thanks again for all the great info!
Eric
bkreigsr 03-10-2006 06:40 AM
mfi
http://forums.pelicanparts.com/uploa...1142001597.jpg
Cire 03-10-2006 06:44 AM
205 HP... Wow. That would be great!!! Again, I am impressed. = ) What do you guess the total cost of the engine was? Is the case a 3R or a 7R?
I have a 2.2 and a 2.4 Engine. The 2.4 has a 7R case. I was thinking about punching out the 2.2 to a 2.4, but if I can get to 205 HP by buying larger pistons that might be best... But it sounds like you have many other additions to yours.
Eric
bkreigsr 03-10-2006 07:03 AM
case was the original one that was in the 73, second rebuild. total cost was way more than I care to admit, (my wife might be looking on). work was done about 6-7 yrs ago, and there was no expense spared. fyi case had to machined to accept the 86mm jugs. check out this thread to see where the car is now.
http://www.pelicanbbs.com/showthread.php?threadid=250731&highlight=coast+to+ coast+farewell+tour
Cire 03-10-2006 07:14 AM
OHHH Your killin me... You got rid of that sweet car? = )
Thats the way hobbies go. Spend all your money on it to get it where you want and then once you are finally happy, you sell it to get something you can start working on again. = )
LOL Still SWEET Stuff!!!
Eric
bkreigsr 03-10-2006 07:25 AM
not so fast on the sympathy part Eric, it's still in the family.
Here's a final shot with the next 'project' car...
http://forums.pelicanparts.com/uploa...1142004287.jpg
Plavan 03-10-2006 07:30 AM
I am building a spare 2.5L long stroke race motor right now. I am waiting for the Aluminum case and heads to get done by Ollies. I will be using 86.7MM custom J&E pistons at 10.5 or 11:0 to 1 compression. Since I am using SC intake valves, I have to use a GE 60 profile cam because of valve overlap. This motor will be a screamer with better torque than my short stroke 2.5L. I have a feeling I will love this motor just like my short stroke Aase built. 2.5L's are great sounding motors! I have 46mm PMO's on mine.
Good luck, and have fun with it.
Here is my 2.5L short stoke dyno numbers at the wheels:
http://forums.pelicanparts.com/uploa...1142004507.jpg
jluetjen 03-10-2006 10:32 AM
Chad; Are you going to dyno you're new engine? It would be great to see how the two different versions of 2.5's compare, even though it sounds like they'll have different cams and valve sizes (both of which will make a bigger difference then the stroke in the engine's performance I suspect).
Plavan 03-10-2006 11:19 AM
Yes, that is the plan. I want to see the difference too. My short stroke 2.5 has a GE80 profile cams with stock 2.7 valves. So there will be a difference. I do not rev the short stoke over 7.5K (although it is good for 8.3k to 8.5K) My thoughts are to take advantage of the long stroke torque at the lower RPM's since I do not rev the short stroke all that high anyway. I am going to keep the stock exhaust valves, but bump the intakes up to SC valves. I am enlarging the intake ports and exhaust ports a few mm. The GE 60 cam will allow me to use the bigger intake valves, with a little more grunt in the lower RPM's.
Should be fun :). Not that there is anything wrong with my current setup.
Cire 03-10-2006 11:51 AM
So if I want low end torque (off Road car) do I want a 2.2 that is punched out to a 2.4 or do I want a 2.4 that is converted to a 2.5?
So many choices...
Thanks.
Eric
bkreigsr 03-10-2006 12:00 PM
how about a custom cam grind, where you specify the torque curve? 2.2, 2.4, 2.5 can all be made to pull at low-end.
jluetjen 03-10-2006 12:54 PM
Eric. more cc's equals more torque. In general terms it's that simple. Where you put it in the rev range is a fuction of the specifications of your engine -- specifically the cam spec's. In regards to that subject, I put pretty much all that I know into this thread.
