Loprene heater hoses
Several years ago, I installed loprene hoses from both exchangers to the flapper boxes. I was really impressed how easy they were to manipulate in the tight confines.
Not so easy to take off, I have found. They were fused to both the exchanger and the flapper. Removing them will destroy them and require some scraping to remove the residue. Disappointing to find that I have to replace them like this. I guess I need to stock a couple of them in the garage. Does this same thing happen with the heater hoses that Aircraft Spruce and Specialty sells?? Brian Last edited by Brian K. Haggard; 02-05-2006 at 08:04 AM.. |
I think not... as the SCEET and SCAT pieces are high grade silicone....don't know for sure, though....
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Does anybody have some decent pictures of the Loprene installed? Also what the finished ends look like?
I just installed some of the OE Black Paper hoses and while the right side went on fine, the left was a b-e-a-r (and it still isn't 100% on there). I run SSIs and I've heard the OE doesn't match up too well with the left side. I don't mind popping for the Loprene but I'd like to make sure the quality is there. Thanks, Scott
Scott Perry 2004 VW Golf TDI 1974.5 MGB GT |
scott..had the same problem..left side, oem hose. i would up having to use a floor jack to get the car high enough so i could fit underneath well enough to get some leverage.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
I spent upwards of an hour messing with it. It's barely on there now. If it comes off I'll have to slice the edge so it can get over and then clamp it really good.
Talk about frustrating... I would GLADLY pay for an extra 1 mm of width (or less on the exchanger) on the hose so it would fit. Good god.
Scott Perry 2004 VW Golf TDI 1974.5 MGB GT Last edited by 1yearonLy; 03-07-2006 at 04:01 PM.. |
Get the SCAT or SCEET product...you can even choose single or double wall construction....fits fine as I've used this for the application being discussed. High quality....nice orange color , too
![]() - Wil
Formerly bb80sc
Wil is right......again....
http://www.airsuppliers.com/aircraftparts/THERMOID.asp Getting ready to place an order myself.
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
or here...with options on construction...
http://www.aircraftspruce.com/menus/search.php type in the word "SCEET" or "SCAT" in the embedded search engine - Wil
I've used the scat stuff, works well, but can tear when installing! so buy a bit extra just in case..
Thanks, I'm on it.
