Autodidactic user
Does anyone recognize this tool? Know how to use it?
It says "USAG model 162/25 Fili 25 max" on the tool. The shaft in the center goes up and down three levels using the red lever on the side and has a very sharp blade on top. The white you see on the triangle piece on top are rollers - there are six of them. Anyone got any clues? I got when I bought a collection of USAG tools. ![]() ![]() ![]()
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
My guess would be a tubing cutter of some kind....
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
maybe a scoring tool, for pipe - lengthwise?
86 Carrera Targa - Garnet Red Metallic 88 928 S4 - Gran Prix White |
Cable sheath cutter; it's an older?/different version of this tool:
http://www.usag-tools.com/prodotti/famiglia.htm?id=161# |
Jim could be right...the rollers aren't aligned well for a tubing cutter...Who knows? USAG is Italian, right???
Enlarge the image in the link and look at it.
pull back the plunger with blade and place cable inside of rollers. Move blade into cable sheath, adjust for depth and pull cable through slicing sheath for removal. Mine you can place anywhere on the cable and rotate around the outside and then pull the cable out, which will leave the cable exposed for inserting into battery lugs, or electrical panel lugs.
2003 VW Passat 4 motion 1972 911 Targa 1997 Boxster 1952 H-D K model (dirt track project) Ghosts of a few 914s & Formula Vee |
Yup! That's Italian! Kind of like a Ferrari...
It's a Martian marital aid
It's a widget remover.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
circumciser
'69 911 Targa w/ 3.2 |
Dudes from Mars to Earth are crossing their legs now
Autodidactic user
Thanks for all the help, looks like you guys hit it right on the head (pardon the pun).
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) Last edited by David E. Clark; 03-08-2006 at 09:23 AM.. |
