-   -   Fuchs polishing--how to remove spider webbing? (http://forums.pelicanparts.com/porsche-911-technical-forum/270585-fuchs-polishing-how-remove-spider-webbing.html)
JonT 03-08-2006 08:30 PM
I've searched the boards and jewelers rouge and 4" buffing wheel was supposed to be 'da bomb' but that really seems to bring out a spider webbing/grainy finish out in the aluminum under my garage flourescent lights. Is there a final step after this to bring out the mirror finish? Thanks
89911 03-08-2006 09:26 PM
Chances are that you didn't get the fine scratches out when you started buffing with the rouge. You can either use some tripoli (a final application that is a fine scratch remover), or some 1500 wet sand paper. Then hit it with the rouge. Mothers aluminum polish is also nice for a final finish. Don't be too hard on yourself. I've seen fuchs from a finisher that many use here and they had many fine scratches in them.http://forums.pelicanparts.com/uploa...1141881908.jpg
