-   -   Can injectors get plugged? (http://forums.pelicanparts.com/porsche-911-technical-forum/270748-can-injectors-get-plugged.html)
long board 03-09-2006 07:36 PM
Howdy, 77 2.7 with CIS. Doesn't seem like it's running on all 6, but not a spark problem. Do/can injectors get plugged?
Hugh R 03-09-2006 07:46 PM
Absolutely!! Don't know anything about your car, but try a can of Chevron Techron, accept no alternatives! Then drive the crap out of it.
GMR911 03-09-2006 08:08 PM
Had a plugged fuel injector, ran a can of techron through it, Fixed the poblem. Now every oil change I run a bottle of techron through the system, then change oil
ThePointman 03-09-2006 08:14 PM
Can you buy the can O Techron at any Chevron? Anyone know if it is available in Canada? I take it that Techron is a fuel additive? If it is a fuel additive what does it do exactly?
Hayabusa 03-09-2006 08:15 PM
I highly recommend 'Redline' Injector Cleaner!!!
Hugh R 03-09-2006 08:21 PM
Try the chain auto parts stores, cheaper than at Chevron by a lot. Its not an additive, its an injector cleaner.
cab83_750 03-09-2006 11:14 PM
I second that. Never buy Techron at the Chevron station.......way, way too much $$. Go to PepBoys. I buy mine in cases at Costco. Not sure if it is actually cheaper at Costco since whenever I go to Costco you tend to ignore your budget
:D :D
For example, "Honey, I am buying eggs, bacon and milk at Costo." 2 hours later you come home with mdse worth $400.00 :rolleyes: :rolleyes: :D heh heh heh
planeguy67 03-10-2006 10:24 AM
Of course, if you buy gas at Chevron, it comes with Techron already in it for free.
PatrickB 03-10-2006 11:31 AM
Sometimes a $10 bottle of miracle juice isn't going to cut it...
Don't discount the possibility that your almost 30 year old injectors might have exceeded their useful life...
After chasing an intermittent rough running problem on my 3.2 for nearly 2 years, it turned out to be a couple of bad injectors. I replaced just about everything except the injectors prior... With a new set of injectors, the car has never run better with a 140k miles and counting...
rcecale 03-10-2006 05:30 PM
A couple of us Pelicans were discussing this just yesterday. Technical Service Bulletin 2510, released December 6, 1985 says:
"Partially restricted fuel injectors can be cleaned through the following procedure and material:
1. Fill up fuel tank
2. Pour 20 ounces of "Techron" into the fuel tank.
Note: Techron is marketed by Chevron
3. The car should be driven until the fuel tank is half empty.
4. Refill the fuel tank.
5. This procedure, as outlined from points 1 to 4 should then be repeated 2 additional times.
6. To keep injectors clean, we recommend adding 20 ounces of Techron after 5 fuel tank refills. However, never more than 20 ounces per 3,000 miles."
'nuff said!
Randy
