1980 911 SC Shifter advice needed
The shifting rod on my 1980 911 SC is able to swivel around (left & right) - this make shifting difficult. Anyone run into this issue and have any advice for what might be wrong and how to fix it?
Old 03-09-2006, 09:23 PM
The common answer is to replace the shift coupler and shift rod bushings.
gary
Old 03-09-2006, 09:38 PM
Yes the shifter bushings (ball cup, shift rod, coupler) need to be replaced.
Not a hard project. I think there is an article and then many threads on this website.
Also 101 projects book outlines this.
I did this when I first got my P-car. Much improved shifting!
Let's see from what I remember, the hardest part was taking apart the coupler. there are threads that describe different techniques from using a press or hammering it out using the support of a proper sized socket.
Also use tape and/or a marker to mark off the alignment of the shift coupler and shift rod so you won't have too much trouble with adjustment when it is back together.
Have fun!!
Quincy
Fountain Valley, CA
'83 SC, '13 P-GTS
"Air cooled, fountain pen guy, living in a water cooled, iPhone world"
Old 03-09-2006, 10:39 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
Hi jass, I have the same problem, and will be replacing all the bushings over the next couple of weeks. I am also installing the factory SS at the same time (another "whilst you are in there" project!) - I'll let you know who I get on
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 03-10-2006, 12:55 AM
durn for'ner
livi's Avatar
Please do, Pål. I also have the ball cup, shift rod and a (complete) coupler in a box ready to install. Let us know the pitfalls.
Markus
Resident Fluffer
Carrera '85
Old 03-10-2006, 04:23 AM
coolcavaracing.com
Kroggers's Avatar
You want to come and help me Markus
Old 03-10-2006, 04:39 AM
durn for'ner
livi's Avatar
What I REALLY want is for this damn winter to fu3k off ALREADY !!
Markus
Resident Fluffer
Carrera '85
Old 03-10-2006, 04:47 AM
coolcavaracing.com
Kroggers's Avatar
Don't I know it......
Old 03-10-2006, 10:09 AM
Somatic Negative Optimist
Gunter's Avatar
I think jass means the whole shift rod swivels around.
I suspect that the upper part of the shifter has come lose from the lower part.
Search for a diagram for the shift housing that shows the details.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-10-2006, 10:37 AM
The shaft is epoxied into a receptacle and the bottom of the Shift rod. You can either epoxy with JB Weld (or similar) or tack weld into place. Also a good time to do the ball cup and shaft bushing.
Warren & Ron, may you rest in Peace.
Old 03-10-2006, 10:53 AM
Here's a link describing the procedure: Stick shift came loose - what holds it on?
Old 03-10-2006, 10:56 AM
randywebb's Avatar
inspect everthing carefully for cracks - some have posted re cracks in/near the epoxy; at the end of the shift tube & etc.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-10-2006, 12:09 PM
