Air Medal or two
915 side cover
Are the nuts on the ring gear side cover special ?? Pulled my ring gear today ( looking for the slop ) and for awhile could not understand why the cover would not come off..closer inspection what looks like helicoil over one of the studs acting as a nut. looked at all the other nuts and they all have what appears to be a insert or helicoil in them..weird.. and my ring gear say 774 on it good/bad ?
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
RETIRED
Locknuts with vinyl?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Air Medal or two
No...reg. looking nuts, all have some sort of insert in them.....well except for the one which had come out giving me some grief
Those are all metal type lock nuts; sometimes called prevailing torque lock nuts.
Air Medal or two
all I know is they are differant.
Air Medal or two
my ring gear has 7.74 stamped in it, and has 31 teeth dose that reveal the ratio ??
Crotchety Old Bastard
The ring gear will have 31 teeth. Count the teeth on the pinion gear. Could be 7 or 8. Normally a side cover does not have locking nuts.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Air Medal or two
thanks- no lock nuts, look std. till ya look close, some kind of helicoil in everyone (one came out ) and was left on the stud impairing my cover removal. I will replace all the nuts,no big deal,just weird.
Three of the five 915 transmissions I've rebuilt/or am rebuilding have these locknuts on the side plate with the metal inserts (wire coils). The use of them appeared to have ended with the SC's. Jim
Air Medal or two
Thanx Jim !!!,, was wondering what weird concoction I had run into
