khamul02's Avatar
Images on this BBS (editing & uploading)
I've seen several people addressing the whole image problem so many are having. Thought I would start my own thread on this.
If you are unable to purchase photoshop & use the save for web option try this:
http://www.gimp.org/
It is free & will allow you to resize & export images.
Keep in mind that for most of the stuff we look at on this board 500 to 600 pixels by 5 or 600 pixels is usually plenty large enough. Also, 60% jpeg quality is more than enough. There are a ton of images on the board that are using no compression & are rather large. If you are really anal about putting up a high quality image use 80% jpeg compression. I assure you 95% of the population can't tell the difference between 60% & 80%.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 03-14-2006, 06:15 AM
