-   -   Leak Down Results (http://forums.pelicanparts.com/porsche-911-technical-forum/271330-leak-down-results.html)
biergut 03-13-2006 01:09 PM
Leak Down Results
Leak Down Results
Need opinions ...
PPI on track car ... 964 3.6
Leak down : (Cylinder 1 thru 6)
Cold: 15% 5% 12% 9% 8% 9%
Warm: 5% 5% 8% 9% 5% 9%
Hold or fold?
BierGut
Rot 911 03-13-2006 01:14 PM
Leakdown results on their own rarely tell the whole story. What are the compression results? Where was the air leaking from (sump, oil tank, etc.)?
biergut 03-13-2006 01:18 PM
Kurt -
Do not know where it was leaking from ... compression test was not performed.
Rot 911 03-13-2006 01:23 PM
Originally posted by biergut
Kurt -
Then you are left with an imcomplete PPI. Cylinders 3,4 & 6 are a bit borderline, but without a compression test who really knows?
JR_NYC 03-13-2006 06:17 PM
Old relevant threads that I used a while back and bookmarked:
http://forums.pelicanparts.com/showthread.php?s=&threadid=200890&highlight=leakdo wn
http://forums.pelicanparts.com/showthread.php?s=&threadid=201414&highlight=leakdo wn
Also useful:
http://www.pelicanparts.com/techarticles/mult_Engine_Rebuild/mult_engine_rebuild-2.htm
biergut 03-13-2006 06:50 PM
JR - Thank you very much! It is very informative and is helpful with this decision.
Cheers.
