Light Show Under the Hood! New Wires?
I was changing out my air filter tonight and was getting a slight miss at idle. I kept the engine running, turned off every garage light and saw several blue arcs coming from a myriad of wires on both sides of the engine! I would'nt call it a Tampa Bay lightening storm, but it was from several sources. Occassionaly I would also hear a "tick" do wn toweard the distributor cap. Several of the wires are in contact with the valve covers. The wire set is over 5-years old and were aftermarket with Beru connectors. Certainly not OEM or braided covered.
Can I assume these are toast? Replace or re-adjust? Whats the rule on arcing ignition wires?
Bob
73.5T 2.4/CIS
Old 03-13-2006, 07:59 PM
fred cook's Avatar
Cool Arcing wires.....
Replace. There is really no good way to "fix" them. Try the Magnecor wires, you will like them.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 03-13-2006, 08:04 PM
Designer King
Paulporsche's Avatar
Time for a change. You don't need the OE braided wires.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 03-13-2006, 08:05 PM
Glasgow 911SC's Avatar
Is there any reason OE wires are so expensive? Most parts suppliers over here are asking £115 ($200) for a set. What is the difference between those and making a set up using the likes of these?
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 03-14-2006, 01:54 PM
