Hard brake line replacement
Can anyone recommend a fair labor time for replacing all except the through tunnel hard brake lines on a 86 northern born 911 that are so rusty all break when trying to replace the flex lines.
Old 03-14-2006, 06:17 PM
jluetjen's Avatar
If it costs more then $70, it's cheaper to just buy the flaring tool and do it yourself. All that you need is the flairing tool, a hacksaw and it you really want to spend money a tube bending tool.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-15-2006, 05:12 AM
captainrb's Avatar
I replace the hard lines on my '73 because with front and rear coil overs,the front struts do not have a purchase point for the hard line to the brake caliper. Also the rears needed to be replaced because when replacing steel trailing arms with aluminum ones ,the old hard line was too long and bending a big 'u' in line didn't seem correct. So I replaced the hard lines with aeroequip s.s. lines. It worked out just fine. Trying to cut,bend new hard lines,can be 'pain'. with the s.s.line its an easy bolt on operation. The cost for fittings and lines was about $60.00 I bought mine at American street rod, 1-800-990-1912 and talk to Jay tell him what lengh you want and he will know what type fittings you'll need.
More is better and too much is JUST enough
Old 03-15-2006, 08:23 AM
John Brandt's Avatar
I would guess most shops would call that a 3 or 4 hour job... much beyond that and its a gouge. Those lines shouldn't be rusty though because they're copper.
Old 03-15-2006, 09:40 AM
I'm going to be doing this myself very soon - If you search, you'll find some posts in response to my questions with some good info and links.
-Brian
Old 03-15-2006, 09:56 AM
paslantnose's Avatar
No brake line ever made is copper, it simply cannot stand the pressures involved with braking systems.
They may be copper plated steel to resist corrosion.
1980 911SC Slant Nose
Can you say MegaSquirt !
Old 03-15-2006, 10:03 AM
Early brakes lines are plated steel; later lines are a copper-nickel alloy called Cunifer.
copper brake lines
Old 03-15-2006, 03:35 PM
I don't know about a stock '86, but when I installed 930 brakes on my '88, I had to make some. I'm betting you don't even need the flaring setup, just get the appropriate lengths from any autoparts store (NAPA, Autozone, etc. all carry them ), a cheap (less than $10 bending tool), and fabricate your own. It isn't difficult at all.
Old 03-15-2006, 03:58 PM
Related question: To remove the line that runs through the belly pan of the car to the rear splitter. Is it as simple as removing the grommet on both ends and fishing the thing out? Can the new one be threaded throuhg relatively easily? Thanks.
-Brian
Old 03-15-2006, 09:04 PM
jluetjen's Avatar
I've done that, but I seem to remember having the engine and transmission out of the car at the time which really simplified the process.
John
'69 911E
Old 03-16-2006, 04:26 AM
golfnow's Avatar
No I tried it and ended up bending the line to make it fit
so latter when I dropped the engin and trans I put in a another new one
Mike Minister of YEP
1986 targa 3.2 " RED"
1970 Little T (Wife’s car)
Gruppe B # 917
Old 03-16-2006, 04:41 AM
Thanks - the engine is out so that's not a problem. Looks like the opportune time to do it. So it pretty much slides out in and in that case?
-Brian
Old 03-16-2006, 05:24 AM
Kolibri
blackbird225's Avatar
I'm doing it right now. Go to discount auto parts, get the <$10 tool and a few hours later your ok with all new steel lines. Bending is so easy you'll laugh.
1942 VW Kübelwagen
1940 Zündapp KS 600
1941 Zündapp KS 750
1975 Volvo C303 TGBII
1967 Honda S90, 1975 CB550
Old 03-16-2006, 06:30 AM
Kolibri
Oh yeah, when you bend a hard turn, might be a good idea to TAPE the fittings to either end. Else, after a nice fabrication, you're stuck w/ both fittings on one end. HEHE ask me how I know this...
Michael
1942 VW Kübelwagen
1940 Zündapp KS 600
1941 Zündapp KS 750
Old 03-16-2006, 06:32 AM
I guess I didn't post my Question right. I have a customer that came to me to replace the pads rotors and calipers as well the flex lines. When I told him the hard lines were frozen and would break and there would be a considerable amount of labor to replace the hard lines he couldn't understand why I would be charging him more. As I understand the engine and transmission has to be removed to replace the left rear hard line coming from the tunnel line.
Old 03-16-2006, 08:23 PM
Why not cut the end off the line shortening, reflare (put new fitting on first) and replace the flexible line with a longer piece?
-Brian
Old 03-16-2006, 09:04 PM
To answer your question more directly, I can't see why it cant be done without removeing the engine and transmission. A partial drop might make it easier.
-Brian
Old 03-16-2006, 09:05 PM
