nixter's Avatar
Used CAT. How do I know condition?
Hey guys I'm trying to find a used CAT and I'm just curious if there's anyway to tell the condition of one.
Thanks,
Nix
1980 911 SC widebody, Black/Black.
1993 BMW M5. Silver/Black.
Old 03-17-2006, 10:32 AM
Take it off a car that has a fresh emissions sticker???
Old 03-17-2006, 12:14 PM
nixter's Avatar
right. Well if anyone has an extra i'd love to take it off their hands!
nix
Old 03-17-2006, 12:15 PM
ianc's Avatar
That's a good one. I guess your criteria amounts to it not being plugged? Perhaps you could blow air through it in some way to test?
Just a guess...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 03-17-2006, 01:09 PM
Take a strong flashlight and shine in one end. If you can see any light at all, it's probably ok. If not, it may be bad. Also if your HC count is high, or it's over 15 years old, it is bad.
Old 03-17-2006, 04:53 PM
sushinav's Avatar
I have one from an 88 that appears to be in really good shape, and is supposed to have about 60k miles on it, but I have no way of telling other than it's visual condition. If you can find a way to test them off the car (my car is sold), I will test it for you if you want to buy it. Send me a PM.
Cheers,
Jason
...sick with gearheadia
Old 03-17-2006, 05:06 PM
Demetri's Avatar
There are two main ways CATs go bad. Either they clog or wear out. If you can see thru it, it is probably not clogged. Figuring out if it is worn out is the tough one. The only way I know of telling whether or not it is worn out is by installing it on a car and measuring the heat of the exhaust pipe right before and right after the CAT. It should be substantially hotter after the CAT. If it isn't, then it is probably worn out.
Old 03-17-2006, 05:36 PM
RETIRED
Joe Bob's Avatar
They're cheap....why bother with used?
2012 ML350 3.0 Turbo Diesel
Old 03-17-2006, 05:54 PM
nixter's Avatar
like how much?
Old 03-17-2006, 05:57 PM
RETIRED
Joe Bob's Avatar
Installed less then 200 USD in most cases...and SC doesn't need a certified CARB approved model. Any thing that will fit can be welded up and installed.
Call your local muff shop and ask.
Old 03-17-2006, 05:59 PM
Make Bruins Great Again
Por_sha911's Avatar
Also consider a sport cat that is less restrictive on the airflow.
Joe
Old 03-17-2006, 06:07 PM
nixter's Avatar
Cheers,
Jason
you have a pm!
nix
Old 03-17-2006, 06:41 PM
What might a used cat in good condition go for? I think I have one, with about 20,000 miles on it, taken off and in storage for 16 years, from 87.
Len
Old 03-18-2006, 08:50 AM
