Headrage's Avatar
Need some jetting advice
Need some advice on jetting for my car. It's a 2.7 with cis cams running about 9.5-1 compression with 40mm webbers and stock ignition. Normal driving will be at sea level with the occasional 4000 ft run to get over the grapevine.
Whatya guys recommend???
Old 03-17-2006, 01:55 PM
Headrage's Avatar
Just a little bumperoo.
Kinda like to do this tomorrow.
Thanks...
Old 03-17-2006, 05:50 PM
just a start 60 idels 180 air F3 em tubes 135 mains
Old 03-17-2006, 06:07 PM
Headrage's Avatar
It has 60 idles in it now and runs way too fat.
Old 03-17-2006, 06:28 PM
Hi:
60 idles ARE indeed way too fat,...
Use 32-34mm venturies with 55 idles, 140-150 mains, F26 emulsion tubes and 180 air correctors.
Make sure your fuel pressure is 3.5 psi and your float levels are PERFECT. You also need a very good fuel filter setup since Weber's are quite sensitive to dirt & water.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-17-2006, 07:28 PM
