valve adjustment
hey all...im trying to adjust the valves right now but the 101 projects book doesn't give too good a desc of where the i gotta stick the feeler gauge. I've adjusted valves on an acura before but this seems a little tougher...do i put the feeler gauge right at the top of the valve spring? and plus it seems a little tough to get in...do you guys loosen it before adjusting?
david
Old 03-18-2006, 11:45 AM
450knotOffice's Avatar
Yes. Loosen the adjusting nut first, stick the feeler gage in, then tighten it to specification. Otherwise you will have a very hard time slipping the gage in (as you've found).
Good luck to you.
Old 03-18-2006, 11:58 AM
Scott R's Avatar
Second that method, also read every thread you can find, getting the "feel" of a correctly adjusted valve is a bit of a science. I kind of equate to having someone stand on a piece of paper, and then you pulling it out from under him.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-18-2006, 12:07 PM
absolutely brilliant alternative method by Racer2.7-->
valve adjustment
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-18-2006, 12:59 PM
HarryD's Avatar
valve adjustment
- Wil
And now a Tech Article Here.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-25-2007, 08:01 AM
http://forums.pelicanparts.com/showt...acer+AND+valve
- Wil
+1
1989 Carrera 3.2 Silver Anniversary Edition
2007 BMW 750Li
2005 Honda Odyssey EX-L
http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html
Old 08-26-2007, 10:22 PM
Thrlls's Avatar
valve adjustment
- Wil
Mahalo Wil!
I was looking for something about valve adjustments knowing it will only be a matter of time once I get my car!
Oh...and a Big MAHALO to Racer2.7 for his contribution!!
Woody
Slow n Fast
1984 Guards Red 911 Carrera
Old 08-26-2007, 11:26 PM
