964 windshield fits on 911 SC ?
Hello, so I found a good deal on 964 windshield for my
80 911 SC. I did my search and couldn't find answer
If the 964 glass will fit the SC. There's consensus on
Some does some don't.. and with 964 seal.
Any idea? I'm sure someone's done it before.
Here's the glass.
Old 06-23-2023, 02:13 PM
Gotta ise the 964 seal with it.
206 637 4071
Old 06-23-2023, 02:34 PM
Ok I'm confused.. I thought this are 964 glass
Now diggin in deep the web.. found out it's 993.
Anybody confirm?
Sigla
43r 001047
Old 06-23-2023, 02:57 PM
Anybody? Don't want to pull the trigger and find it doesn't work.
Old 06-24-2023, 11:10 AM
Yes it does, I’ve had one in my SC for about 15 years. You need to use a 964 seal and the fitter needs to fill the voids with the usual sealant/mastic stuff. No problem, more aerodynamic so the car is much faster and there is less wind noise. The latter of those two statements is true…. You also get a built in aerial which, if you want to use it, will require an amplifier for the screen, or at least think that’s what it was called.
Ian
Old 06-24-2023, 11:14 AM
Ian
Thank you Ian, so it is a 964 glass not a 993
Will get the 964 seal and I'll install it myself.
I see what you meant by the sealant, it's around
the corners where the seal doesn't fit flush all the
Way.
Thanks again,
Ogi
Old 06-24-2023, 12:31 PM
SWS911's Avatar
Looks like 993 glass to me with that "seal" and shadowing around the edge. Typical of a "glue in" windshield.
Old 02-17-2025, 12:05 PM
proporsche's Avatar
i had on my 911 883 for 12 years no problem til it got broken now i have 964 with proper seal-no alu.triming.
get the porsche dealer rubber seal -i went through 3 different types
1985 911 with original 501 587 miles...807 226 km
Old 02-17-2025, 12:19 PM
