drag racing the short bus
dd74's Avatar
Tekniq steering wheel snap off quick release system...
I've grown tired of rolling the seat back to get in and out of my car, and was thinking of getting something like this. I have a Momo Protipo wheel, so fitament doesn't seem to be a problem.
So, my question is, does anyone use this system? If so, how do you like it? I'm thinking of going with the track version, though I'll still drive my car on the street.
Here's a link for more information.
http://www.tekniqauto.com/US/snapoff/snapoff.htm
Thanks.
The Terror of Tiny Town
Old 03-18-2006, 11:16 PM
Administrator
Jack Olsen's Avatar
It's great. I've got one. Thom Fitzpatrick's got one. Chris Campbell's got one.
Definitely get the race one, without the lock.
Old 03-19-2006, 01:02 AM
JWest's Avatar
The race version is more expensive, and I really wanted black finish anyway, so I bought the street version and removed the lock by driving out a pin. I found a black plastic plug at Ace to fill the lock hole.
I like it a lot.
James
JWest Engineering
Old 03-19-2006, 05:09 AM
I ran the race model on my '88 Carrera for three years. It's the best!
Not only enables easy entry and access for working on your interior, but a good theft deterrent.
I agree with Jack, get the race one.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 03-19-2006, 05:12 AM
Administrator
Jack Olsen's Avatar
I got mine when they first started making them, and actually have a street version with no lock in the cylinder -- like what James describes doing. If this is cheaper, and the black color works better for someone, then it seems like a smart way to save a few bucks.
Old 03-19-2006, 10:00 AM
jakermc's Avatar
I've got a track version also. One side sticks a little sometimes, but otherwise I love it. I also bought a 'shorty' hub from them to keep my wheel at the same position relative to my body as it was before the install.
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 03-19-2006, 12:09 PM
Registered Cruiser
jorian's Avatar
Has anyone noticed any play in the adapter and how thick is it?
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 03-19-2006, 01:02 PM
Administrator
Jack Olsen's Avatar
Put a tiny bit of lightweight oil or WD40 on the retracting pins, and this will go away.
Old 03-19-2006, 01:45 PM
I got mine here http://www.tcracing.org/
they're very nice
word of caution:
they will fit a momo style wheel, but not a momo-style hub
you need a raid or nardi style hub
(unless they changed the design)
so double check!
a momo-style has a 70mm bolt circle, with the bolts starting at 12 o-clock (then 2,4,6 etc)
a raid/nardi/personal style has a 75mm bolt circle, starting at 1 o-clock (then 3,5,7 etc)
IIRC, you can mount both styles of wheel to the quick release, but only the raid/nardi style hub
WWW.9GEAR.NL
Old 03-19-2006, 05:18 PM
Somewhere in the Midwest
MotoSook's Avatar
I realize this is a very old thread, but I'm interested to know if the disconnect locks up firm (no play). Also, does the tapered pins hold tension over time keeping the wheel from developing slop.
Anyone?
Old 02-23-2014, 07:55 AM
Northern Motorhead
wildcat077's Avatar
Sook,
Have a look at Lifeline quick releases,they're based in the UK but i just purchased one for my 944 and the price is very reasonable and the quality is outstanding !
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 02-23-2014, 08:46 AM
MotoSook's Avatar
Thanks, Phil. Where did you buy it? I did a quick search and they are $330 or so. The Snap-off is $190. I'm sure the lifeline is a well made product but I'm just looking for a functional QR that is slop free.
Old 02-23-2014, 09:16 AM
1SIK930's Avatar
I'm looking to buy the Rothsport Racing quick release. From all the track guys I've talked to, it's got no play.
'87 930..Sold
'72 911T 3.2 MFI Twin Plug race motor, full cage, full coilovers, too many suspension mods to list, wide body, Fiske wheels, R888, fuel cell, fiberglass everything, 2091lbs
"You don't have to be CRAZY to own a sports car, but it helps"
Old 02-23-2014, 09:28 AM
J-Mac's Avatar
Do any of the options allow the horn to remain functional? Thanks.
J Mac
Current 0
Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified
Old 02-23-2014, 09:44 AM
MotoSook's Avatar
As luck would have it, a buddy's car that is stored at my place has the Snap Off QR on it. I checked it out and it met my expectations, so I ordered one.
J-MAC, Snap-on makes a horn adaptor.
Old 02-23-2014, 11:20 AM
Racer
winders's Avatar
The Rothsport is the best quick release available. I have it in my race car and absolutely love it!! It is a tapered design that should never get loose and there is only one way to put the wheel on so you don't have to worry about getting the wheel on with the correction orientation.
Worth every penny!!!!
Old 02-23-2014, 11:39 AM
Northern Motorhead
wildcat077's Avatar
Sook,
I bought it locally from one of our shops for $250.00 Canadian,there is absolutely no slop and it's the same price for the weld on type or the hub type.In my case, on the 944 the PO had welded on a cheap version which i removed and replaced with the Lifeline unit !
Cheers
Phil
Cheers
Phil
Old 02-23-2014, 01:49 PM
Racer
winders's Avatar
I am not a fan of the spline systems. The Rothsport unit is the same type of design as the Porsche Motorsports unit. It is tapered so as it wears it stays tight and there can be no slop.
See here:
Old 02-23-2014, 02:11 PM
Administrator
Jack Olsen's Avatar
Lots of good options.
For what it's worth, my Tekniq is still performing flawlessly all these years later. The horn works with it just fine.
It's the least expensive, too.
Old 02-23-2014, 02:45 PM
Ferrino's Avatar
Originally Posted by Jeroen View Post
I got mine here TC Racing: Welcome
they're very nice
word of caution:
so double check!
Looking to order one of these (have a MOMO hub adapter and a MOMO Prototipo). Can someone please clarify this statement? It doesn't make sense that it would fit the MOMO wheel, but not the MOMO hub adapter - isn't it supposed to fit either wheel and either hub?
Old 12-23-2015, 08:52 AM
