sporatic tach
sometimes the tach works, sometimes it doesnt move at all and sometimes it bounces all over the place. any ideas where i should look, i figure a loose wire or a bad ground.
*NEW 1969 911t targa soft window option
1967 912 Targa Soft Window
1989 911 GP White Cabriolet
1970 911t
2001 Chevy Silverado 1500
1997 Audi A4 Quattro 2.8
2003 Acura TL Type S
1973 911t 3.0 track car (SOLD)
Old 03-21-2006, 09:33 AM
BUMP
1970 911t
Old 03-21-2006, 10:31 AM
Autodidactic user
David E. Clark's Avatar
Check your points. The tach gets it's signal from the points. If the gap is incorrect or there is some oil on the surface this could lead to the symptoms you describe. Make sure the gap is perfect and then run a piece of paper between the points to remove any oil. Don't forget to double check the gap with a dwell meter.
On my 73, the breaker point gap is: .035mm (.014 inch) and the dwell angle: 38º +/- 3º @ 900 RPM Vacuum hose connected (38º or greater @ 6,000 RPM w/ vacuum hose off). It's probably the same on yours but double check to be certain.
If this doesn't fix the problem, check the voltage from the alternator and voltage regulator. Incorrect alternator output or a voltage regulator that's not working properly can also lead to a bouncing tach. Hope this helps.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 03-21-2006, 01:18 PM
Slumlord
Porsche_monkey's Avatar
The bouncing tach has often been attributed to a failing alternator, I haven't been able to figure out why, but it seems to be a common problem.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 03-21-2006, 01:30 PM
mschuep's Avatar
As well as the above 2, I would check the electrical connections on the back of the tach. I bumped one loose when changing my gauge lights, afterward the tach was bouncing pretty irratically...
-Matt
1985 Targa
Old 03-21-2006, 01:32 PM
