*( 911 air filter
Just how is one to change the air filter in a 89 911? Doesn't seem to want to be changed.
Old 11-27-2005, 07:39 PM
ianc's Avatar
Is this a trick question?
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 11-27-2005, 07:44 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
4 clips, remove airbox cover and filter - replace.
The bottom rear clip is the hardest to reach.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 11-27-2005, 10:56 PM
Well it sounds simple enough. We tried and it seems thst the sover hits the engine hinge and the A/C hose plus how do you get your hand to the rear of the box to undo the clips in the rear. Had a hard enough time trying to remove the plugs. Only got two out on that side. Thanks for the help.
RT.
Old 11-28-2005, 05:03 AM
Wider is Better
wholberg's Avatar
If all the clips are undone, then it comes out easily. There are no hinges, so when the clips are undone, the cover lifts about an inch and then slides out.
plus how do you get your hand to the rear of the box to undo the clips in the rear. [/QUOTE]
You just snake your hand back there. I reach over the top with my left arm and down. If you have extremely large arms, it might be difficult, but I am not a small man and I can reach the clips. The bottom rear one is a real b**** though.
Good luck.
Wider is Better
Old 11-28-2005, 06:12 AM
The clips *DO* hang up after they're released....these are "hinged" type. You may have to fiddle-fart each clip to get them to "release".
Hint .... after you're done removing the front cover.... consider cutting off the entire face of the front cover except for a 1" wide "band" that includes the reinforcing ribs. Then you'll end up with a clone of the "Cup" airbox. It does a couple of things. It gives you line-of-sight access to the 4 clips, and makes any maintenance like valve adjustment and oil filter changes much easier. A search on this board will give more details.
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-28-2005, 08:46 AM
greglepore's Avatar
Agree w/ Wil-I recently did this (had a cone filter in the interim) and I have almost as much access as with the cone, MUCH easier access to the clips, and it looks better than the cone (or the factory snorkel, IMHO).
If you don't want to sacrifice the stock lid, you can buy complete airboxes cheaply enough on the parts board.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 11-28-2005, 04:10 PM
Driving member
jester911's Avatar
Reach in from the left side of the maf and you will get it.
Hopefully your arms are not too short or to big.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 11-28-2005, 04:49 PM
billroth's Avatar
Just renewing this thread.
I too am having trouble with this. Do you have to take the AC compressor down to get the last latch off?
1985 911 Coupe Black
1985 911 Cab GP White (killed)
Old 03-19-2006, 10:27 PM
UFLYICU
ZOA NOM's Avatar
No, you should be able to reach all four clips and remove the air filter without removing anything for access.
prc-racing.com
Old 03-19-2006, 10:32 PM
billroth's Avatar
To get the lower back latch, where do I put my friggin' hand? I can get the top one from the top but can't get close to the lower one. Fat hands I guess.
Old 03-19-2006, 10:49 PM
slodave's Avatar
Imagine your arm is a snake and shove it in there! When your arm hurts and you have not undone the hindge, you are almost there!
Now you know why the dealers charge so much for basic service
Dave
Old 03-19-2006, 11:12 PM
durn for'ner
livi's Avatar
I gave up and drove six months with the lower, rear clip undone.
Then I asked my almost anorexic brother and he managed to reach it with his spider arms.
Markus
Resident Fluffer
Carrera '85
Old 03-20-2006, 12:00 AM
You can remove the plastic intake snorkel that prevents your arm from reaching the clip. It snaps out.
Old 03-20-2006, 02:20 AM
Wider is Better
wholberg's Avatar
I reach over the top of the motor with my left hand and shove my arm back there until my elbow is past the AFM, and then I can reach down to the clip. Of course, by this time I am essentially laying on top of the motor with at least one foot off the ground, and I do it in a closed garage so the neighbors won't talk.
Wider is Better
Old 03-20-2006, 08:22 AM
Barrpete's Avatar
I get my wife to clip the ones in the back. She has skinnier arms!
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 03-20-2006, 08:42 AM
Cut the lid !!!! .... make a cup lid !!!
Wil
Wil Ferch
Old 03-20-2006, 08:57 AM
billroth's Avatar
Great idea. I can get my wife more involved and maybe even get her to like the car!
Old 03-20-2006, 04:54 PM
Used Up User
imcarthur's Avatar
Just look at all the space!
I'm with Wil . . .
Ian
'87 Carrera Cab
Old 03-20-2006, 05:08 PM
ianc's Avatar
No problems with water getting in there Ian? How's the sound?
ianc
Old 03-20-2006, 05:10 PM
