Source for T-style 911ST front bumper?
Anyone have a source?
Most of the suppliers (eg. GT racing, Rennspeed, AIR etc) only have the widened S-style front bumper. Aussie rules require the use of a T (ie. no lip) front bumper.
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
I have a steel one. I don't know what it is worth but it came on a car that had factory steel ST flares. It is the correct curvature but the center section has some rust. I could cut the terminal ends off and you could fit them to a stock factory bumper.
PM me if you are interested. Chris
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
You mention fiberglass manufacturers. Is that what you want? A stock T bumper in FG? I would simply cut the "lip" off. Close enough.
Edit: I just went out and looked at one that I have. The area at the lower front wheel arch may have to be reworked a bit. A pint of resin and a yard of FG matt and you could lay up the ends over some waxed aluminum sheet contoured to match the rest of the curvature.. Last edited by Zeke; 03-23-2006 at 04:51 PM.. |
chris - your pm's appear to be turned off.
milt - i'm not after a stock T bumper but a bumper widened to fit with 9" ST front gaurds, but in the T style (ie. no S lower lip). here's some pic's of what i'm after. (it may be simpler to modify a stock T bumper but i thought i'd check for off-the-shelfs first)
My PM's seem to be working.
My front bumper is exactly like the ones pictured above...except the silver one...niether the flares or the bumper are correct. Chris
pm sent
