Carrera Charlie's Avatar
Simple Horn Fix!
I just made a simple discovery that may assist someone out there ... my horn pad was always depressed towards the left side of the steering wheel and the contact for the horn remained closed (always on - thus the missing horn when I purchased the car)! The horn pad also felt loose and would wobble. I fixed both last night quite easily!
First, the three tabs that hold the pad to the steering wheel must be equally straight - one was slightly bent. The bent tab was enough to tip the pad to tip towards the left and cause the contact to remain closed. By carefully prying with a screwdriver, the tab is easily realigned to the original position and the pad returns to a balanced location:
The ingenious part of the fix was stopping the wobble! The reason for the wobble was a tired rubber cup on the back of the pad. After years of faithful service, it no longer had the resiliency to center the pad and push it back to center. It needed a boost and being the frugal person I am (and not having access to new parts at 10:00 PM) I noticed the size of the cup was approximately the same size as a milk bottle cap. Finding one in my store of oil collection bottles, I test fit the cap and it was a perfect fit! After trimming out the inner sealing ring, which interfered with the steering wheel nut, I slipped it on and it centered perfectly with a nice resistance and return on both sides of the wheel:
I pinched the horns from my '74 Carrera (waiting for full rebuild) and now had sound where before there was none!
I now feel better that I can make people aware of me (I nearly soiled myself when a Ford F350 was backing up at a traffic light and I could not roll the window down fast enough to shout - stopped 5 inches away from my hood)!!
Hopes this helps someone out there - enjoy!
Regards,
Charlie - GruppeB #013
'69 911E Targa
'72 VW Bug
'74 Carrera Targa
'85 LandCruiser (FJ-60)
'89 MB 190E 2.6
'97 Town & Country (family hauler)
Old 03-24-2006, 09:28 AM
Charlie,
I love those fixes that don't cost anything - great job! I'll have to add plastic milk bottle tops to my tool box.
Was it 2% or whole milk?
Rex
1975 911s
1997 Saab 900s
Old 03-24-2006, 09:47 AM
Banned
gassy's Avatar
Send a message via ICQ to gassy Send a message via AIM to gassy Send a message via Yahoo to gassy Send a message via Skype™ to gassy
How do you get the horn pad off? I think I have the same problem. HEY KIDS! COME DRINK YOUR MILK!
Old 03-24-2006, 11:08 AM
Been here a while
or, buy a new part, I did this last year, it was a couple of bucks for a new rubber ring.
-Lewis
looking for 1972 911t motor XR584, S/N 6121622
Old 03-24-2006, 11:12 AM
Gassy,
The horn pad rotates counter-clockwise (with some firm pressure) to approximately 30 degrees and comes off:
It's the reverse to put it back on - a very easy process.
Lewis,
You're right ... and I will buy a replacement part, but it's so much fun "kluge-ing" something together!!
Regards,
'69 911E Targa
'72 VW Bug
'74 Carrera Targa
'89 MB 190E 2.6
Old 03-24-2006, 12:07 PM
defcon65's Avatar
I like it. What can you fix with an empty beer can?
Joe
85 Carrera
64 Honda Dream - for sale
71 Hodaka Super Rat - keeper
Old 03-24-2006, 12:08 PM
Been here a while
a rough day at the office
-L
Old 03-24-2006, 12:10 PM
Banned
gassy's Avatar
thanks Charlie
Old 03-24-2006, 12:22 PM
durn for'ner
livi's Avatar
Nice upgrade !
I have another problem. My horn does not work at all. Canīt figure out why.
Markus
Resident Fluffer
Carrera '85
Old 03-24-2006, 12:52 PM
Thank You for posting this. This weekend I finally got fed up. I could no longer tolerate the random horn honks when going around corners or over bumps. I've replaced the rubber boot and switch in the past, but the symptoms persisted.
I searched and found this thread. I was desperate, so I gave it a try.
I installed my Skim milk cap today and after several hours of testing I'm proud to report my horn problems are solved.
I'm sure there's a more eloquent solution with a spring or something but sometimes simple is best. I too removed the inner seal. The cap really reduces the wobble of the horn pad which seems to be the culprit with the random honks.
Old 11-19-2006, 02:30 PM
1973_911T,
I'm glad I could contribute back to this board and help someone else - I've learned so much here that has helped me keep my '69 on the road! Thanks for letting me know this was useful!
Have a great Thanksgiving!!
Regards,
'69 911E Targa
'72 VW Bug
'74 Carrera Targa
'89 MB 190E 2.6
Old 11-20-2006, 12:20 PM
Eddyvdw's Avatar
Hi Charlie,
I'm also fixing the steering wheel and the horn pad is wobbling like crazy. The only part new to me is the rubber ring between the wheel and horn pad (which makes perfectly sense btw). Is that an original part? Can't find it in the part list either.
Thanks,
Ed
Old 01-18-2010, 10:13 PM
HarryD's Avatar
It appears in the 914 catalog.
Pelican Parts - Product Information: 901-347-823-01-M100
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-18-2010, 11:41 PM
