I'm re-installing some speakers, however the wire color changed somewhere along the way from amp to speaker, how do I check wich is positive and wich is negative?
(I don't have a meter) Thank you, George
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
What you are concerned about is the "phase". If you swap "+" and "-", the speaker will be out of phase. Both speaker can be out of phase so long as the are in the same phase. It is a question of the speaker cones travelling in the same direction, as opposed to one side pushing and the other side pulling. Try hooking them up and listening. Then switch + and - on ONE speaker. Does it now sound louder and fuller or weaker and thin? Choose the one that sounds best. Now, if I could find some speaker that easily fit in my door without cutting. Maybe someone has answered this already...searching...
1985 911 Coupe Black 1985 911 Cab GP White (killed) |
Very easy. Take a standard flashlight battery and touch the speaker wires to the terminals. Watch the movement of the speaker cone. When the cone moves out when the wires are touched to the terminal, which ever wire is on the + side of the battery, that is the "positive" terminal. The other wire is the "negative" terminal.
RoyB Dartmouth, Ma 1987 Targa, Black on Black Photo Album http://public.fotki.com/Rbertalotto/ |
Harbor Freight has a meter that works well enough for this type of work, and it costs all of $4.99, less when on sale. You own a 20+ year old car, trust me you will need it
A continuity tester makes this type of testing easy. In a car I doubt if you could tell the difference anyway- and there is no harm if connected out of phase.Enjoy the music Gary |
I know of no way to use a multimeter to check speaker phase.
If the speakers are out of phase there will be a dramatic loss of bass response. Harm done....:-)
Used Up User
When setting up systems at hif shows etc, we (the hifi industry) all use the very sophisticated 9V battery test as Roy described . . .
Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
Be carefull with 9V.............This can damage a car speaker (and many home speakers also). Use a 1.5 volt battery to be safe.
Used Up User
Our speakers are tough, they can handle it.
You're right, a smaller voltage will work fine too.Ian
Everything stated above is true..but in my anal retentive world I would rip out the old spliced wire and replace with a new piece of the proper guage and length. Who knows what you will find when you dig it out.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Wider is Better
They were these speakers. http://www.sonicelectronix.com/item_4295.html
Wider is Better |
The question is how do you test the "WIRE" for phasing assuming there are no identification and both wires are black in color.
fast and dirty...hook them up..50/50 chance they will be correct. Then reverse the wires on one speaker. If there is less bass then you had it right to begin with. If there is more bass then now it is right. Helps if you can rig it up so you can flip back and forth quickly...also you might want to turn the treble down some to help you hear the bottom. The right thing to do is to replace the wires..who knows what cluster f**k is between your new speakers and the amp. lol, you would have been done by now.
How about checking current flow between the wire and ground?
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Do the battery test at the radio end of the wires.
'69 911E 2.7MFI ;996TT;987.2 CaymanS '71 Volvo P1800E wife's; AMG SLK wife's '71 Volvo race car 944S; 986S ; 734WHP drift car (son's) |
I apreciate the attempts in helping me but here it is -
I don't have a meter Wires go via RCA from radio to AMP the go from amp in all black wires to speaker, this is where phasing is in question.
The 1.5 Volt battery test will be your answer: We'll assume that wires from radio to AMP are correctly polarized (RCA). From the AMP, disconnect wires to Left speaker and do the battery test: If the speaker cone pushes out you have the positive wire on the positive terminal and the negative wire on the negative terminal, so hook it up to your amp accordingly. Now do the same with the Right speaker.
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
