Fog lights not working
Both Foglights have stopped working on my 84.
IS there a relay that works the fog lights ? Where is it ?
UFLYICU
Yes. It's on top of the fuse panel in the trunk, closest to the front of the car. The row of red cans above the fuses are relays in the pic below. Fog Relay is far right. You can pull the relay and short across the plug to confirm the relay is bad.
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 03-28-2006 at 07:43 AM.. |
Thank You
Yup, it's most probably your relay. Mine died a few months ago and I replaced it and it was fixed.
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() |
Thread Tools | |
Rate This Thread | |
