Electronic Door locks not working
My electronic door locks used to work fine ('86 Carrera). Then they just stopped. I can unlock both doors with the key, but can't lock them with the key. I also can't lock the driver side with the door open even by pushing on the knob or turning the little wheel. Center lock button on lower console doesn't do anything. Is it just the relay or something else? If it is the relay, where is it?
1964 356 C 1970 911T 1974 914 2.0 1986 Carrera Spec911 race car #76 1990 Carrera 2 |
Try this link:
central locking failure... I had the same problem. There is a multi piece rod with a ball cup connector which cracks. The rod is superceded bya one piece 964 part which replaces the assembly. It is cheap and available through our host. Sorry do not have the part number handy. Simply remove the door panel and look at the loc actuator and all will become obvious. Hope this helps, JP
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
Thanks for the help!!! (I did a search, but I used "electronic lock" so I didn't come up with that thread).
I will find the part number tonight and post it in this thread so future searchers can find.
JP
964.537.571.00 is the correct part and it replaces three former parts. Here is a picture of the part. The former clip is at the bottom left, and the attacment to the power lock actuator is at upper right.
You're the man, rsrfan. Next time you are in Reno, I will buy you a beer.
Wider is Better
Re: Electronic Door locks not working
Wider is Better |
that rod connects the lock solenoid to the lock. They're known to break.
I'm w/ wholberg on that you probably have an electrical issue.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
