-   -   Dropping Motor. What else should I do while it's out (http://forums.pelicanparts.com/porsche-911-technical-forum/274492-dropping-motor-what-else-should-i-do-while-its-out.html)
ausgezeichnet 03-30-2006 07:36 PM
Hey guys,
In the next few weeks I plan on dropping my motor for the first time to have the transmission refreshed. Here is what I also plan on doing while it's out. Any other suggestions?
1. Replace engine sound pad
2. Remove and clean fuel injectors
3. Replace vacuum lines
4. Replace rear (and front) shocks
5. Replace motor mounts
Thanks.
coloradoporsche 03-30-2006 07:54 PM
Wayne's 101 projects book has a nice list.
oneblueyedog 03-30-2006 08:01 PM
Detail the engine compartment to make it gleam.
Straighten those AC fins.
Repaint the engine compartment.
Powdercoat the engine tin.
Rebuild engine.
New paper hoses?
Airbox cover has been repainted with epoxy appliance paint and stickers from Porsche since this picture for more gleam! Dirt and dust just tumble off the surfaces.
http://forums.pelicanparts.com/uploa...1143777417.jpg
porschenut 03-30-2006 08:02 PM
Thoroughly clean the engine bay and detail the engine. It's so nice when they're clean and the only time you can really do it is when the engine is out.
Also:
1. Convert to twin plug
2. Upgrade to wacky cams
3. Add ITB's
4. Mahle 3.4 HC P&C's
87coupe 03-30-2006 08:04 PM
Valve adjustment, very easy with the engine out.
Detail engine compartment / motor.
Have the tins powder coated.
etc, etc, all depends on how much you want to do & how long you plan to have the motor out. Also, make sure you get all the old foam and as much adhesive off before you install the new engine pad.
oneblueyedog 03-30-2006 08:20 PM
Oh yea, polish and clearcoat the fan. Powdercoat the fan housing.
JeremyD 03-30-2006 08:37 PM
Take a picture of you inside the engine bay
RickM 03-30-2006 08:54 PM
Remove and document all plated hardware and have it replated ...CAD or yellow dye chromate.
randywebb 03-30-2006 09:20 PM
Clean the engine bay well -- here's mine
http://forums.pelicanparts.com/uploads7/a1143782443.jpg
ZOA NOM 03-30-2006 09:27 PM
Replace speed & reference sensors on the flywheel.
lusso 03-31-2006 04:55 AM
Mike,
If you need any help give a shout. Are you going to Hershey?
Dave
Jascha 03-31-2006 05:21 AM
In addition to the 30K service stuff (plugs valve adjustment, etc) be sure to replace and re-torque the intake manifold gaskets (a snap with the engine out...)
na2ub 03-31-2006 05:57 AM
Replace common oil leak seals.
Doug
wcc 03-31-2006 06:00 AM
Replace rear shocks.
Blanco 03-31-2006 06:58 AM
Accelerator bushings, shifter bushings, oil sensor, thermostat o-ring, cv-joints
I did the above+ when I dropped my engine to replace with a newer tranny.
JTL 03-31-2006 09:08 AM
I'm just finishing up the very same project. I spent a ton of time on just cleaning dirt and grime off the engine/trans and bay area. A quick steam cleaning would have been ideal before doing anything else.
Other things I did: clutch, pilot bearing and rear seal, repacked cv's, rear shocks, cam oil lines, chain cover gaskets, op switch, replaced various seals and gaskets, and detailed/painted parts. I decided against expandable oil return tubes because they didn't look adequate enough. They would have been easy to do while the ugly and heavy exhaust is out but...
jt
-84 targa
Bobboloo 03-31-2006 09:19 AM
One more vote for replacing oil seals. Particularly for the pressure and temp sensors.
Wil Ferch 03-31-2006 10:03 AM
-valve adjustment
- replace hard-to-reach top of engine oil seals ( thermostat, various senders)
- maybe even the fuel lines if this is a 3.2...as it seems to be.
- Wil
randywebb 03-31-2006 10:48 AM
oil tank stuff...
& if it's a 72 or earlier, swap the bolts around on the banana arms
good time to put in the Al arms if you don't have them - you will actually have room to torque the bolts w/engine out.
defcon65 03-31-2006 02:10 PM
install twin turbo
post pic w/Zappa reference
