Do 3.2 intake runners use gaskets?
I need to remove my right intake runner to fix an oil leak at the rear.
Do the intake runners use gaskets to attach to the manifold? |
Yes, two per port which sandwich the plastic insulator.
Very common place to find intake leaks....often urged to replace..
They get "sucked" into the intake "airstream"...(or so it appears) once you discover an intake leak. Wil |
NO, do not reuse them. I also recommend you relpace the "plastic" block between the heads and the manifold. They can get "out of shape". All of the parts required are really inexpensive....\
Cheers |
| All times are GMT -8. The time now is 09:15 PM. |
